Review Contents:
Gigabyte GA-EP45T-Extreme Motherboard Review
by 3oh6     |     August 20, 2008
Voltage Regulation
The Voltage Regulation section is where we have a look at the voltages the motherboard sets. How close they are to what is selected in the BIOS, changes from idle to load, vDROOP, and measuring read points. These are all the things we will look at. For all results in this section, we will be using the same setup as we have throughout the review and the system will be set to the XMP profile of the Corsair Dominator memory. Voltages will be set manually, however, so we have values to compare to. Here are a couple photos of the read points used for the various measurements with a calibrated UEI DM393 True RMS digital multimeter.
The leads sticking through to the underside of the motherboard provide the read points for vCORE and vMCH which can be seen in the first photo. Any of the circled leads should give the same reading for the appropriate component. The vTT and vPLL voltage read points are a bit smaller and impossible to get at without removing the stock cooling and can be seen in the second photo above. The third photo outlines the read points for vDIMM and is a bit tricky to get to while running. The inside of the capacitor pointed toward the DIMM slot is the end you can read from. All voltage readings using the DMM were grounded on the ground of an open fan header in the lower left portion of the motherboard. Let's now take a look at the voltage chart for the GA-EP45T-Extreme.
BIOS SetBIOS ReportEasyTune6DMM
Idle
DMM
Load
vCORE1.325v1.300v 1.280v*1.289v1.266v
VTT1.50000vx1.50000v1.495v1.495v
vPLL1.76000vx1.76000v1.767v1.767v
vMCH1.2000vx1.20000v1.201v1.199v
vDIMM1.96000v2.000v2.000v*1.991v1.991v
What you select in the BIOS is pretty close to what you get with this board for the most part. We have already mentioned the slight vDIMM over voltage which happens throughout the voltage spectrum but everything else we could measure seemed to be pretty close. vCORE obviously has some vDROOP on this board when going from idle to load and there is a pinch of drop from what is selected in the BIOS to what is being supplied at idle. Un-like some other motherboards, there is no option in the BIOS to eliminate vDROOP but it isn't that bad with our setup. Obviously a quad core is going to uncover a little more vDROOP but we don't have a quad core on hand to test for that. Here is the vCORE chart from a quick 30 minute OCCT run at our XMP settings.
vCORE Chart from OCCT
Again, the vDROOP is there, but it is solid as a rock. There is very little variation of the vCORE indicating a nice clean supply of power going to the CPU.
Heat & Acoustical Testing
We are not going to continue to harp on Gigabyte for the heat sink design here. We think we got our point across in the layout section. Despite the fact that the design is rather clumsy and poorly thought out, it still has the ability to cool the chip set of the motherboard well, even under pretty intense conditions as we saw in the FSB testing section. Running the system stable at 1.50 vMCH at 550FSB with a Performance Level of 10 does me the chip set heat sink does its job well. It still doesn't mean we have to like it though.
There clearly is a lack of design, and thought that went into the chip set heat sink design and if there was an on-die temperature sensor, it would be easily proven. We just don't think that there is any need to water cool this chip set, and especially not in the manner the stock heat sink does it. It really does add cost to the board and sure while it may appear that the board is a premium board with the Hybrid-Silent Pipe, it definitely helps make the GA-EP45T-Extreme carry a premium price tag.
March 14, 2010
The Republic of Gamers series from ASUS has always been known for being among the best in the industry and the Rampage motherboards are at the their forefront.  The new Rampage III Extreme will soon b...
March 11, 2010
ASUS hasn't been making much noise in the high-end AMD market as of late and has instead concentrated their new Republic of Gamers series motherboards towards Intel users.  That is all about to change...
March 3, 2010
ASUS has long been known for their Republic of Gamers series of motherboards and while they have products already in place for both of Intel's P55 and X58 platforms, they felt it was time to take thin...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/9406-gigabyte-ga-ep45t-extreme-motherboard-review.html
Posted By Date
Gigabyte GA-EP45T-EXTREME DDR3 Motherboard Review - [OC]ModShop Today 07:35 PM
[Thread ufficiale] Il Thread dei consigli per gli acquisti - hwProject Forum March 15, 2010 10:10 AM
Gigabyte GA-EP45T-EXTREME DDR3 Motherboard - Big Bruin October 19, 2009 07:20 PM
GSkill (2x1G) DDR3 1333 PC10600 (F3-10600CL9D-2GBNQ) Budget RAM OC run October 11, 2009 08:55 AM
Review Magnet - We search the Net, so you don't have to. September 30, 2009 04:43 AM
EP45T-Extreme: quel bios choisir? September 11, 2009 05:18 AM
Iron, Coppis e la mobo perduta... - hwProject Forum August 18, 2009 03:33 AM
MSN Shopping June 13, 2009 08:14 AM
Enthusiast Hardware News and Niche Market Hardware Guide - Ninjalane.com May 31, 2009 12:25 PM
Gigabyte GA-EP45T-EXTREME motherboard - PCSTATS.com May 26, 2009 04:57 AM
Q9550 EP45T-Extreme Corsair XMS3 How to achieve working OC??? Currently being funny - Overclockers Australia Forums May 16, 2009 05:51 AM
Brand new looking at Gigabyte EX58-Extreme - XtremeSystems Forums April 26, 2009 03:43 AM
Futuremark - News - Newsarticle April 25, 2009 06:54 PM
Air Cooled Gallery - Page 164 - XtremeSystems Forums April 22, 2009 04:55 AM
Gigabyte GA-EP45T-EXTREME DDR3 Motherboard Review April 20, 2009 08:55 AM
techPowerUp! :: Review Database April 14, 2009 06:42 AM
Gigabyte GA-EP45T-EXTREME DDR3 Motherboard Review April 11, 2009 03:53 PM
NCIX.com - Buy Gigabyte EP45T-EXTREME ATX LGA775 P45 DDR3OC 2PCI-E SATA RAID Sound GLAN 1394 CrossFireX Motherboard - GA-EP45T-EXTREME In Canada. April 4, 2009 06:36 PM
