Review Contents:
ASRock P45R2000-WiFi Motherboard Review
by Eldonko     |     August 6, 2008
Overclocking Results
Let’s see how the P45R2000-WiFi lives up to the true test of a board, overclocking! The board is packed with features, uses the latest and greatest chipset, but all that means nothing for an enthusiast if the board does not overclock well. Well we had a lot of trouble trying to overclock this board and we can say it certainly is not user friendly overclocking for a novice user.
First off, using any FSB jumper configuration other than FSB1600 would allow hardly any overclocking at all, maybe 200Mhz at the most if memory was underclocked. Also, with the FSB1333 configuration (which is recommended with a 1333FSB CPU), the board was not even stable at stock with Optimized Defaults and XMP selected. We had to loosen Performance Level to 10 in Windows to have stability at stock. Overclocking FSB by 1 led to insta crash (likely because of strap change and MCH issue common of P45 boards). After several days of tweaking, it was determined that an overclock was possible in FSB1600 mode and we were able to achieve an overclock of 4005Mhz. Benchmarks were possible at 4100Mhz, but for the five hour OCCT test to finish we had to reduce to 4005Mhz.
Testing memory independently, the board was sub par for both DDR2 and DDR3. We were able to run stock on the DDR3 kit (666Mhz 7-7-7-20) but not a Mhz more without memory errors. DDR2 would not even run at stock speeds on any divider and corrupted Windows at only 450Mhz.
We suspect the issues with overclocking on this board are BIOS related. It seems the memory and MCH tables are not set up properly or there is an issue with memory registers as the board showed many symptoms of memory incompatibility. FSB maxed out around 465-470 even using very high for NB and VTT voltages and for 24/7 stability it had to be run closer to 450. One point to mention is GTLREF was best run at the 0.615xVTT setting, this added quite a bit of stability at high FSB.
Even with issues with FSB and memory clocking, a reasonable overclock of 4005Mhz was achieved, a gain of 33%. To accomplish this, the FSB1600 configuration and 3:4 memory divider were used; giving RAM speed of 593Mhz (DDR1186) and 7-6-6-20. It is important to note however that a lot of work went into achieving stability. These settings will be used throughout the benchmarking sections.
March 14, 2010
The Republic of Gamers series from ASUS has always been known for being among the best in the industry and the Rampage motherboards are at the their forefront.  The new Rampage III Extreme will soon b...
March 11, 2010
ASUS hasn't been making much noise in the high-end AMD market as of late and has instead concentrated their new Republic of Gamers series motherboards towards Intel users.  That is all about to change...
March 3, 2010
ASUS has long been known for their Republic of Gamers series of motherboards and while they have products already in place for both of Intel's P55 and X58 platforms, they felt it was time to take thin...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/8709-asrock-p45r2000-wifi-motherboard-review.html
Posted By Date
Mouse e keyboard non funzionano in accensione - Page 2 - Windows Vista - Italian March 18, 2010 01:03 PM
Mouse e keyboard non funzionano in accensione - Windows Vista - Italian February 9, 2010 08:53 AM
Futuremark - News - Newsarticle December 25, 2009 07:15 AM
techPowerUp! :: Review Database November 6, 2009 03:54 PM
Review of ASRock P45R2000-WiFi, Review ASRock P45R2000-WiFi - Mainboards October 23, 2009 09:25 AM
GA-X48T-DQ6 or GA-X48-DQ6??? - PC PowerPlay Forums September 19, 2009 11:41 PM
August 2008 - Overclockers Australia August 13, 2009 01:59 PM
Board Comparison - Page 2 - Tech Jamaica - Jamaica's Technology Portal Forums August 3, 2009 08:15 PM
????? ??? ??????? ?? ???? ???? ??? ????? - ????? ?? - ??????? ???????? ???? ????? June 23, 2009 03:09 AM
Futuremark - News - Newsarticle June 7, 2009 07:27 AM
Enthusiast Hardware News and Niche Market Hardware Guide - Ninjalane.com May 31, 2009 12:28 PM
Week of August 3, 2008 May 25, 2009 08:48 AM
Asrock P45R 2000 Wifi motherboard May 6, 2009 11:03 AM
ASRock P45R2000-WiFi DDR2 / DDR3 (P45) Motherboard Review April 12, 2009 05:40 PM
HardwareFerg: ASRock P45R2000-WiFi DDR2 / DDR3 Motherboard Review por HardwareCanucks April 12, 2009 04:09 AM
Mainboards durchsuchen | 3DCenter.org April 11, 2009 04:37 AM
ASRock P45R2000-WiFi DDR2 / DDR3 (P45) Motherboard Review @ Hardware Canucks April 10, 2009 06:37 AM
ASRock P45R2000-WiFi DDR2 / DDR3 (P45) Motherboard Review April 7, 2009 04:09 AM
ASRock P45R2000-WiFi DDR2 / DDR3 (P45) motherboard April 6, 2009 02:35 AM
ASRock P43 and P45 Motherboards Reviewed - Reviews anderer Magazine - PCTreiber.NET April 5, 2009 03:17 PM
