| by Eldonko | August 6, 2008 | ||
| Intel P45 Chipset & ASRock P45R2000-WiFi Features Intel P45 Chipset ![]() The new P45 chipset by Intel supports a variety of features including new Intel 1600 MHz Front Side Bus processors, dual-channel 1600 MHz DDR3, Extreme Memory Profiles (Intel XMP), next-generation dual PCI Express 2.0 lanes, and Intel Extreme Tuning, allowing for maximum platform performance. The Intel P45 Express Chipset is driving PCIE 2.0 to mainstream users, delivering up to 16 GB/s bandwidth, twice the bandwidth of PCI Express 1.0. The Intel P45 Express Chipset supports either a 1 x 16 or 2 x 8 PCIE2.0 configuration for expandable discrete graphics capability. PCIE2.0 also provides greater flexibility and reliability in design because it is backward compatible with PCIE1.0 and can dynamically manage power and performance through software controls. The greatly improved 16 GB/s of graphics bandwidth capability enables much higher levels of performance on graphics-intensive applications such as high-end gaming and video rendering. ASRock P45R2000-WiFi Features A few notable features on the ASRock P45R2000-WiFi include the ASRock OC Tuner, 7.1 Channel HD Audio, All Solid Capacitors, Yorkfield and Wolfdale CPU support, DDR2/DDR3 hybrid memory, CrossFire support, and WiFI capabilities. A brief summary of each of these features is as follows: ![]() | ||
