Categories
Review Contents:
Mushkin Ascent 2x2GB PC3-12800 DDR3 Kit Review
by 3oh6     |     July 16, 2008
Stability Testing & Overclocking:
Our stability testing methods for memory have been discussed at length in the past, so we are going to simply rely on the explanation from previous reviews. Here is a run-down of what we consider to be stable.
Stability Testing Methodology:
Memory stability, what constitutes stable? What is not considered stable? These questions get hotly debated in enthusiast forums all over the internet like little brush fires on the fringe of an inferno that play havoc with forest fire crews. Everyone has their own opinion about stability, especially when it comes to memory stability. For some, stable means they can do whatever it is on their computer without it crashing, blue-screening, or restarting; whether that means gaming or just surfing the internet. To this user, stable means simply using the computer as they normally would.
Of course, that is not what we would call stable and we do a lot more thorough testing before labeling a memory frequency/timing stable. One of the toughest types of programs on a system has been found to be distributed computing projects such as Rosetta@Home, Folding@Home, World Community Grid, and more. Running 24/7 crunching for one of these great causes is a sure way to find holes in a system if there is truly some instability, unfortunately it takes a considerable amount of time to use them for stability testing so we use the list of programs below to all but guarantee the system to be 24/7 distributed computing stable:
Our stability testing is most definitely up there as far as the toughest in the industry and this is because we want to make sure we are testing for the 24/7 crowd. If you are just looking for benchmarking stability then you will have to find that somewhere else, especially with this being a 4GB kit of memory. Benchmarking is generally reserved for 2x1GB kits as they are a lot easier on the memory controller and clock much higher on average. We are almost ready for the overclocking but before we get to that, we need to make sure this kit can even run the specified timings/frequency that Mushkin has outlined. This is also a great way to test compatibility on the motherboard we are using for this review, the EVGA 790i Ultra-SLI.
Specification Stability Testing:
As was just mentioned, before we start overclocking this beautiful looking kit of Mushkin Ascent memory, we want to see if it even runs the rated frequency and timings at the outlined voltage. Some readers may be wondering why that is even something we have to question but with the different chipsets available and the difficulty that brings for memory manufacturers, the stories of incompatible memory run rampant in computer forums all over the internet. The specification stability testing was added some time ago in light of this situation.
Click for full size screenshot...
We are off to a great start because not only was this memory ready to roll out of the gate at the rated timings and frequency, but it was also quite willing to run at the lowest specified voltage by Mushkin. We simply entered the BIOS and set the primary timings to 7-7-6-18 and the voltage to 1.875v (which equates to 1.86 actual volts). All other voltages were set to the lowest possible with the exception of the SPP voltage which was running at 1.40v as we saw in the screenshot. The simple fact that we can run this kit fully stable at 1.86v should provide us with some overhead because of the voltage we have to play with going up to a specified 1.95v. Let's now see what we can make this memory due above and beyond what it is specified for.
Stability Overclocking:
The approach we take when overclocking is to tackle the three main timing groups that we find with DDR3 modules at the frequencies this kit can run. The stability testing has been outlined above and we will search for our maximum frequencies at CL6, CL7, and CL8. The secondary timings will be determined during testing based on how the memory responds and what it likes, let's see how high the Ascent modules are able to climb on our NVIDIA 790i platform.
Now this is how a kit of memory is suppose to overclock...and a 2x2GB kit none the less. Needless to say, we were quite impressed with what we managed to squeeze out of this memory on the EVGA 790i Ultra-SLI and these results explain why. The first hurdle was to see if DDR3-1600 was possible at CL6 and it certainly was. We had to increase voltage a slight bit over the rated voltage of 1.95v but we were able to really tighten down the timings and get the rated frequency stable at a full timing set below what these Mushkin Ascent modules are spec'd out for.
Moving up to the next common timing set of 7-7-7 provided a very nice boost in frequency but required quite a bit looser secondary timings. This may result in an actual decrease in performance as the 790i chipsets performance in memory intensive tasks really favors tight secondary timings and can actually offset higher frequencies if the secondary timings are too loose. Of course that only goes so far as raw megahertz will eventually win out.
The last timing set we looked at was 8-8-8 and again, the kit just takes off with a little bit of voltage. At 2.01v, the Mushkin Ascents elevated the stable operating frequency to a lofty 990MHz or DDR3-1980. This is just a short 10MHz away from the elusive 1000MHz mark but no matter how hard we tried, we couldn't quite get DDR3-2000 stable in Prime Blend. The one important aspect of this hefty overclock is the massive amount of SPP or north bridge voltage that is required to get full stability. Our 790i sample is modified to provide additional SPP voltage and the appropriate cooling to compensate. In the end, we required 1.67v on the north bridge to accomplish this stability which is a good pinch higher than is even selectable in the BIOS for this motherboard. You will want to keep this in mind when clocking your own kits of this wonderful memory. Below are the screenshots of the stable overclocks we just discussed complete with Memset for full disclosure of secondary timings.
Click for full size screenshots...
We will now utilize these overclocks in the next few sections of benchmarking for a comparison of the various levels of performance of each.
Latest Reviews in RAM
July 17, 2008
It has been a while since we last saw a Mushkin product here at Hardware Canucks but today they return with a bang. Their new Ascent 2x2GB PC3-12800 DDR3 kit has gr...
July 2, 2008
DDR3 has recently begun dropping in price and is looking to make its debut into consumers' everyday component buying mentality. 2x 2GB kits are becoming more and mo...
April 29, 2008
Corsair has long been known for producing some high-end memory kits and their Dominator line is as good as it gets. Today we take a look at the Dominator DDR3 1800M...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/8585-mushkin-ascent-2x2gb-pc3-12800-ddr3-kit-review.html
Posted By Date
DDR3 Computer Memory Review Round Up | MEGATechNews :: Mega Techie Goodness For the Masses September 5, 2008
Koju memoriju kupiti - 2. dio - Stranica 8 - PC Ekspert Forum September 2, 2008
[OC]ModShop - Mushkin Ascent 2x2GB PC3-12800 DDR3 kit August 26, 2008
Mushkin Ascent 2x2GB PC3-12800 Review - Dream PC Forums August 26, 2008
ExtremeTech Discussions - Memory and Performance: The Bottom Line August 26, 2008
3DCenter.org | 3D-Grafikkarten-Benchmarking, Downloads, News & Reviews August 24, 2008
Extreme Memory Help! (DDR3) - techPowerUp! Forums August 19, 2008
PCSTATS.com - Get The 'Stats and Stay Informed! Hardware Comparsion HQ July 30, 2008
RAM DDR3: lista review e prove - Pagina 2 - UFA - United Forum Alliance July 30, 2008
techPowerUp! :: Review Database July 27, 2008
News from around the web (07/24/08) - TechSpot News July 24, 2008
What memory? July 24, 2008
Mushkin Ascent 2x2GB PC3-12800 DDR3 kit - PCSTATS.com July 24, 2008
Ascent XP3-12800 DDR3 - Mushkin Enhanced July 23, 2008
PC Perspective - News July 22, 2008
ASUS Striker II Extreme - Page 64 - XtremeSystems Forums July 22, 2008
Modders-Inc.com - PC Mods, Case Mods, Modding Guides, Hardware Reviews, Hardware News, Forums - Affiliates July 21, 2008
PC Perspective - The #1 Choice for PC Hardware Reviews and Information July 21, 2008
Untitled document July 21, 2008
DailyTech - 7/21/2008 Daily Hardware Reviews -- OCZ Core SSD Edition July 21, 2008
Hardware Round-Up - HotHardware July 19, 2008
Digg - Mushkin Ascent 2x2GB PC3-12800 Review @ Hardware Canucks July 19, 2008
Top news stories - The Tech Report July 18, 2008
Daily Reviews Summary 07/18/08 July 18, 2008
techPowerUp! - The latest in hardware and gaming July 18, 2008
Friday Morning Roundup :: TweakTown July 18, 2008
Blue's News - All the carnage that's fit to post! July 18, 2008
Futuremark - News - Newsarticle July 18, 2008
Friday Shortbread - The Tech Report July 18, 2008
Mushkin Ascent 2x2GB PC3-12800 DDR3 Kit Review July 18, 2008
Mushkin Support Forums • View topic - Ascent 2x2gb PC3-12800 (1600Mhz) Review at HardwareCanucks July 18, 2008
Techgage - Home July 17, 2008
Mushkin Ascent 2x2GB PC3-12800 DDR3 Kit Review - DriverHeaven.net July 17, 2008
