Mushkin Ascent 2x2GB PC3-12800 DDR3 Kit Review
by 3oh6     |     July 16, 2008
Memory Installation & Test Setup:
With standard size heat sinks on memory, we generally just take a couple quick photos of the modules in the testing motherboard. With the added width and height of the Mushkin Ascent heat sinks, however, we will take a few looks at the memory in a couple different setups to see what we might run into. In all honesty though, we don't expect any issues as current generation motherboards are so well laid out that large memory heat sinks are rarely an issue, even with large CPU coolers.
Starting off in the ASUS P5E3-Premium, we can see there are likely not going to be any issues with the larger heat sinks. As we have said, motherboards are better designed and large CPU coolers just don't interfere too much with memory slots anymore. We can, however, see that despite the memory fitting in slots side by side; they do have to bow out a little bit. This really isn't an issue and even in this configuration with another pair in the other two slots, there should be no problems with cooling thanks to the great design of the Ascent heat sinks.
Dropped into the 790i motherboard we will be using for testing, again, there are no clearance issues with the large Thermalright Ultra-120 in place on the CPU and when mounted in parallel slots, we have no problems arise. We will be running the memory in the black slots anyway as they are the preferred slots for memory clocking on reference 790i motherboards.
We will be testing this memory in the EVGA 790i motherboard today but we already know that with a lack of EPP profiles, the memory is simply going to boot up at the default timings and frequency that the motherboard sets. So, we figured we should see how the XMP profiles work in the ASUS P5E3-Premium since it is sitting right here. From left to right we have a pair of CPU-Z screens showing that the board detects the XMP profiles and sets everything up automatically at the BIOS defaults. We can't say enough how much we like the XMP profiles with an XMP compatible motherboard. Getting up and running at spec is as simple as clearing the CMOS. The last two screen shots above are of Memset showing the secondary timings and it is nice to see Mushkin has gone relatively aggressive here. The one exception is tRD (Performance Level) which is set to 7. We would have liked to see a 6 but, we can take care of that manually as the board can handle it no problem. Time to see how our test platform is going to shake down...
Test Platform:
  • Motherboard: EVGA 790i Ultra-120 (BIOS P05)
  • Processor: Intel C2D E8400
  • Processor Cooling: Chilly1 Single Stage Phase Change
  • Memory: Mushkin Ascent 2x2GB PC3-12800 7-7-6-18
  • Power Supply: Silverstone Zeus 560W (ST56ZF)
  • Video Card: HIS HD3870X2 1GB
  • Additional Fans: 120mm 2050RPM/80.5CFM (AD1212MS-A73GL)
  • Hard Drive: 2 x Seagate 7200.9 80GB SATAII 8MB cache
  • OS: Windows Vista Ultimate x64 (with all updates) - For Benchmarks / Windows XP x64 - For Overclocking
As we can see, the testing of this memory will be done on an EVGA 790i Ultra-SLI motherboard that is the same as the NVIDIA reference design. This motherboard has been found to respond quite well to Mushkin Ascent 2x2GB kits as was found in the EVGA forums. We figured if end users were having success with the 790i then we might as well try for ourselves. It is a known fact that the 790i motherboards can sometimes play games with certain kits of memory so we had our fingers crossed as we set everything up.
Another item of note in the list above is the use of two different operating systems. We have used Windows XP Pro x64 for the overclocking of this memory because, well, Vista can sometimes be a major pain in the butt. Personally, I am not a fan of Vista and every chance I get not to use it I take. Memory overclocking can be hit and miss with some of the stability programs we use responding erratically at times. We do, however, switch to Vista Ultimate x64 for the benchmarking so we can run the latest Vantage titles from Futuremark. Let's now find out just how well this 4GB kit of memory runs on said NVIDIA 790i based motherboard.
Latest Reviews in RAM
January 11, 2011
As CPU memory controllers continue to become the bottleneck when it comes to overclocking memory, having modules that can keep up has become increasingly important.  G.Skill's Ripjaws modules are curr...
November 10, 2010
As memory prices have been falling, manufacturers have jumped on the "more is better" bandwagon and are releasing kits with absolutely massive capacities.  In this review we take a look at OCZ's new F...
September 1, 2010
The sub-$150 memory market is thick with products from the likes of Corsair, OCZ, G.Skill, Patriot and so many others.  Mushkin is now adding their name to the list with their new Ridgeback series.  I...
