OCZ Vendetta 2 CPU Cooler Review | ||
| by AkG | July 15, 2008 | ||
| E4600 Performance Results E4600 Performance ResultsIdle Temperatures ![]() ![]() As you can see the Vendetta 2 breezes through the dual core idle phase with some impressively low numbers. Of course, idle numbers are not overly important in the grand scheme of things as its average load numbers which usually determine how far you can push your overclock. Lets check them out next and see if these idle numbers translate into great load performance numbers! Average Load Temperatures ![]() ![]() For all intents and purposes this unit runs a full degree cooler than the (now) second place Xigmatek at loads which have brought more expensive units to their knees. If this CPU cooling solution can keep up this level of performance during the quad core phase it will have bested its Xigmatek brethren to take the number one spot! | ||
