Review Contents:
Sapphire Radeon HD4850 512MB Graphics Card Review
by Michael "SKYMTL" Hoenig     |     July 1, 2008
A Closer Look at the Sapphire HD4850
The first thing many of you will think when you first look at the HD4850 is how similar it looks to its distant relative: the HD3850. If you do a quick one-take, the heatsink looks the same and even the general layout of the PCB is very similar as well. Speaking of the PCB, ATI has once again used their signature red PCB for this card and carries this color into the fan assembly as well.
Aside form the obvious performance differences; the main thing that differentiates this card from the HD4870 is the fact that it uses a single slot cooler. While this may be great for those of you with a premium on space within your case and on your motherboard, it means that hot air from the heatsink will be dumped right back into your case. Single slot coolers also have a history of underperforming when compared to their dual-slot brethren.
The heatsink is somewhat dominated the single 19-bladed, 60mm fan which is used to draw in cool air before pushing it over the copper fins placed over the core. Sapphire has chosen to go with a classy carbon fiber-like patterned sticker on their card which is actually quite nice considering many ATI cards of late have been sporting stickers with either Ruby or odd looking manga characters.
The rearmost portion of the card is partially covered in what looks like one of those dead-sexy Enzotech ramsinks that water cooling aficionados love to use on their graphics cards. These small copper towers are used to disperse the heat generated by the VRM modules they cover.
Unlike the HD4870 which has a pair of PCI-E 6-pin power connectors, the HD4850 consumes less power and therefore only needs only one. This means the engineers were perfectly happy with the 75W a PCI-E 1.1 slot combined with the 75W a 6-pin PCI-E connector are rated to carry in order to power this card.
Looking a bit closer at the layout of the heatsink, we can see that there is a copper runner which runs almost the entire length of the card on one side. Personally, I think this is here to make the heatsink base a bit more rigid but here is a word of advice: this little piece gets bloody hot. Let your card cool down for at least 10 minutes before removing it from your case or you WILL burn yourself.
Instead of directing heat directly towards the back of your case, the heatsink on the HD4850 is slightly curved so its exhaust is directed towards the side, away from the motherboard. This suits us just fine but I would have personally liked to have seen a perforated expansion slot cover included with any card that has a single slot cooler. This would partially alleviate any worries about all the heat getting trapped in no-mans land within your enclosure.
As with nearly all ATI cards these days, the HD4850 has a double Crossfire connector which can be used to daisy-chain one, two, three or even four of these cards together. Meanwhile, on the backside of the card we get the usual pair of DVI-D connectors as well as the video-out port. Since this card supports full audio and video out through a DVI to HDMI dongle, there really isnt a reason to include a stand-alone HDMI connector.
There really isnt much to see on the back of the HD4850 other than the X-shaped hold down plate mounted around the core to make sure the heatsink puts sufficient pressure on the core.
The Sapphire HD4850 is one compact card when compared to both the 9800GTX and the HD4870. It is a mere 9 long which means that it shouldnt have a problem fitting into most mATX HTPC cases as long as they dont require low-profile video cards.
Latest Reviews in Video Cards
March 17, 2010
The HD 5830 was released a few weeks ago and since then we have seen numerous versions from ATI's board partners. Prices have also settled somewhat so this card could have the makings of a good value...
March 10, 2010
Lately, there has been a lot of talk about upcoming overclocked and 2GB HD 5800 series cards which will see the light of day in the next few months. In this sneak peak, we take a look at the ASUS HD ...
March 7, 2010
If you weren't pay close attention to the GPU market a few months ago, you may have missed the launch of the GT 240 series since the launch wasn't preceded by any of the usual marketing or release day...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/8299-sapphire-radeon-hd4850-512mb-graphics-card-review.html
Posted By Date
The Best Way To Cool Video Cards. - Graphics-Cards - Graphic-Displays March 3, 2010 09:22 AM
Accelero S2 and 4850? - [H]ard|Forum February 24, 2010 07:08 AM
quattroworld.com Forums: Off-topic February 20, 2010 05:11 AM
quattroworld.com Forums: Best thing I have done: February 19, 2010 10:11 PM
GTX 260(896MB) vs ATi Radeon 4850 1GB? - Yahoo! Answers February 18, 2010 10:40 PM
Sapphire Radeon HD4850 512MB Graphics Card Review February 13, 2010 12:52 AM
bad cpu? - CPUs - CPU-Components February 8, 2010 02:30 PM
ATI Radeon HD 4850 or Nvidia 8800GS? - Yahoo!7 Answers February 7, 2010 06:50 AM
Cool Mx Graphics - DoChoiNhua.com February 2, 2010 05:08 AM
Sapphire HD4850 stock heatsinks? - ATI - Graphic-Displays January 25, 2010 08:32 AM
Help me, new 4850, new cooler, or nVidia? - ATI - Graphic-Displays January 15, 2010 05:05 PM
fitting the Accelero S1 Rev.2 in ATI 4850 - Graphics-Cards - Graphic-Displays January 11, 2010 07:13 AM
Aftermarket Cooler For 4850 - Page 9 - Overclockers UK Forums January 11, 2010 06:12 AM
Who dugg: Sapphire Radeon HD4850 512MB Review @ Hardware Canucks January 8, 2010 05:28 PM
What's the most powerful passive cooling card nowadays? - Graphics-Cards - Graphic-Displays January 7, 2010 01:11 PM
Need a beginner's guide to replacing a graphics card Heatsink - Graphics-Cards - Graphic-Displays January 6, 2010 01:13 PM
Recommend a Video Card? - Topic Powered by Social Strata January 1, 2010 12:03 AM
Help with installing Accelero S1 Rev 2 on a 4850 - Overclockers Forums December 16, 2009 01:19 PM
Los retrasos en el iMac de 27 pulgadas pueden ser por su alta demanda y no por los defectos en su pantalla December 16, 2009 10:55 AM
SweClockers.com - Forum: Kylning HD4850 November 22, 2009 01:04 PM
HD4850/4870 Aftermarket Coolers - AnandTech Forums November 20, 2009 09:46 AM
S1 and 4870 - AnandTech Forums November 20, 2009 09:46 AM
ATI Graphics Cards Reviews and Benchmarks - GameReplays.org November 1, 2009 05:22 PM
quattroworld.com Forums: Way more than it needs. Even when running at 100% (the GPU)... October 31, 2009 10:14 PM
Changing graphic card October 28, 2009 11:43 PM
Sapphire Radeon HD4850 512MB graphics card - PCSTATS.com October 1, 2009 07:36 PM
Torrents.Md - BitTorrent Tracker Moldova :: View topic - Placi Video/??????????: ?????? ?? ??????, ???????????? (GPU) September 30, 2009 01:58 AM
AnandTech - S1 and 4870 September 28, 2009 03:41 AM
Review - Nvidia geforce 9600 GT silent - Info-momo September 20, 2009 01:35 PM
SweClockers.com - Forum: Fsta flkt p Arctic cooling s1 rev2 September 11, 2009 05:27 AM
8800 GTS Vs HD 4850 - TechEnclave September 6, 2009 06:12 AM
Silent GPU for $200 August 23, 2009 06:39 PM
یŃ}b^炵Ă閼p37 August 22, 2009 09:00 PM
ATI 4850 - Heat issues? - Topic Powered by Eve Community August 19, 2009 10:08 PM
TR Forums • View topic - HD4850 Goes From 88C to 39C Using Accelero S1 August 6, 2009 10:33 AM
Futuremark - News - Newsarticle August 5, 2009 01:06 AM
problema de temperatura con saphire 4870 - VGA Forums August 4, 2009 01:45 AM
ATI 4850 - Heat issues? - Topic Powered by Eve For Enterprise July 26, 2009 10:27 AM
? ?????? ?? ?????????? ATI Radeon HD4850 ?? Arctic Cooling S1 July 8, 2009 01:23 AM
Missing Remote July 6, 2009 11:04 PM
4890 scores up to 15 percent better with DX10.1 July 6, 2009 11:24 AM
problemas con ati 4850 (2 de 4) @ ElOtroLado.net PC Hardware July 4, 2009 11:43 AM
silentpcreview.com | View topic - Diamond Radeon HD4850 July 1, 2009 12:04 AM
SweClockers.com - Forum: passar denna kylare p mitt HD 4850? June 28, 2009 04:15 PM
Sapphire Radeon HD4850 512MB Graphics Card Review | GPU Watch - The Latest Video Card News and Reviews June 25, 2009 05:31 PM
The Best Way To Cool Video Cards. June 25, 2009 07:28 AM
4 4 - BulForum June 25, 2009 04:59 AM
powerfull silent gaming card - Monitors/Video - Whirlpool Broadband Forums June 23, 2009 05:26 AM
6000+ & 4870 cooling June 20, 2009 07:17 PM
AnandTech - 4850 cooling question June 20, 2009 05:28 PM
MWTS: Powercolor HD4850 mounted with aftermarketcooler - VR-Zone IT & Lifestyle Forum! June 19, 2009 03:31 AM
Review of Sapphire Radeon HD 4850 512MB GDDR3 PCIe 100242L, Review Sapphire Radeon HD 4850 512MB GDDR3 PCIe 100242L - PCI-Express - Page 2 of 3 June 17, 2009 05:24 PM
.:: OC-Lab Forum ::. • View topic - Uradna tema - ATi Radeon HD 4000 June 17, 2009 02:29 AM
best air cooler for HD 4850? - Page 3 - Overclock.net - Overclocking.net June 15, 2009 07:26 PM
[Topic Unique] Refroidissement alternatif pour CG - Page 9 - Canardpc.com June 12, 2009 11:28 AM
Radeon HD4850 - 25 - hardwareBG.com June 11, 2009 01:39 PM
Need a beginner's guide to replacing a graphics card Heatsink June 11, 2009 07:02 AM
Sapphire Radeon HD4850 512MB Graphics Card Review June 7, 2009 08:50 AM
.: el Canto de los Duendes :. - photos from tomdan - Fotolog June 4, 2009 04:26 PM
?????? ??? ??????!!! - ADSLgr.com June 4, 2009 05:01 AM
Asus EAH4850 (ATI HD4850) - HardwareLogic June 3, 2009 04:33 AM
HD 4850 | GPU Watch - The Latest Video Card News and Reviews May 30, 2009 09:27 AM
Where is the Sapphire HD 4850 100242? - XtremeSystems Forums May 29, 2009 04:54 AM
A few questions... - Page 2 - Overclock.net - Overclocking.net May 28, 2009 12:25 PM
I guess the 4770's are a pretty hot item. - Rage3D Discussion Area May 28, 2009 11:34 AM
Which aftermarket cooler for 4870? - Overclockers UK Forums May 27, 2009 07:07 PM
SweClockers.com - Forum: Hjlp med montering av kylare [Bilder] May 25, 2009 10:22 AM
Going to mod my 4850, will these parts work? May 25, 2009 03:18 AM
Help me, new 4850, new cooler, or nVidia? May 22, 2009 08:08 AM
4850 - The noise is driving me mad. - Overclockers UK Forums May 22, 2009 03:34 AM
The Best Way To Cool Video Cards. May 21, 2009 11:34 PM
fitting the Accelero S1 Rev.2 in ATI 4850 May 20, 2009 05:24 PM
powerfull silent gaming card - Monitors/Video May 18, 2009 04:24 PM
Incredible: 4770 in XFire beats 4890 AND it's cheaper !!! - Page 3 - techPowerUp! Forums May 18, 2009 06:24 AM
passar en accelero S1 rev2 p ett hd 4850 ? - Minhembio forum May 16, 2009 04:30 PM
La 4850 dual slot de Sapphire et le silence - Canardpc.com May 14, 2009 11:25 AM
Slo-Tech | Test 4850 ter 3870 May 13, 2009 02:27 AM
ணஹ௮ . .. .. ௮ஹண - 199 - May 11, 2009 10:48 AM
Help me, new 4850, new cooler, or nVidia? May 8, 2009 11:39 AM
6000+ & 4870 cooling April 28, 2009 05:33 AM
Chieftec 400w (Ku?i?ta i napajanja) @ Bug Online Forum April 27, 2009 08:15 AM
Best cooling for ATI HD4850 - Page 3 - XtremeSystems Forums April 27, 2009 06:24 AM
[VENDO] HD4850 + acelero s1 rev2 - Pgina 3 - 3DG April 23, 2009 06:17 AM
Arctic Cooling Accelero S1 Rev. 2 review door F for Fragging | Tweakers.net Productreviews April 21, 2009 08:47 AM
AnandTech - accelero s1 nsk2400 April 21, 2009 07:13 AM
Untitled document April 19, 2009 01:51 PM
Which ATI 4850 graphics card should I buy? - Yahoo! UK & Ireland Answers April 19, 2009 11:44 AM
4850 and in need of temperature solutions. April 16, 2009 09:13 AM
Better video playback with the Radeon HD 3850? - Open Tech Support Community April 15, 2009 01:14 PM
AnandTech - Underclocking the 4850 April 15, 2009 11:58 AM
AnandTech - HD4850/4870 Aftermarket Coolers April 13, 2009 04:18 PM
Il mio pc April 12, 2009 02:06 PM
ATI HD 4850? - Mobile-Review.com Forums April 12, 2009 12:48 AM
Silent GPU for $200 April 10, 2009 03:06 PM
TR Forums View topic - HD4850 Goes From 88C to 39C Using Accelero S1 April 10, 2009 11:43 AM
Aftermarket Cooler For 4850 - Page 2 - Overclockers UK Forums April 10, 2009 06:22 AM
Which ATI 4850 graphics card should I buy? - Yahoo! Answers April 10, 2009 05:21 AM
Sapphire Radeon HD4850 512MB Graphics Card Review April 8, 2009 09:01 AM
Radeon HD 4850 or 9800 GT - Page 4 - Overclock.net - Overclocking.net April 8, 2009 04:00 AM
4850 with Zalman VF900? - [H]ard|Forum April 7, 2009 07:36 PM
HD 4850 - ref cooling and Rivatuner 2.10 - Monitors/Video April 7, 2009 10:26 AM
Accelero S2 and 4850? - [H]ard|Forum April 7, 2009 08:42 AM
Diamond Radeon HD4850 | silentpcreview.com April 6, 2009 09:14 PM
AnandTech - 4850 is crashing at stock: I think I've isolated the naked VRMs as the culprit... April 6, 2009 04:34 PM
silentpcreview.com | View topic - HD 4850: Ethics, Warranties, and Aftermarket Coolers April 6, 2009 01:52 PM
Sapphire Radeon HD4850 512MB Graphics Card Review - Madshrimps Forum Madness April 6, 2009 05:58 AM
Going to mod my 4850, will these parts work? April 6, 2009 03:16 AM
HD 4850 Naked (New Cooler added) Zalman VF900 CU - Page 2 - techPowerUp! Forums April 6, 2009 01:45 AM
Neue Benchmarks von 4850/4870 vs. GTX280 und Co. | New benchmarks of 4850/4870 vs. GTX280 and co. - News Archiv - ATi-Forum.de April 5, 2009 04:58 PM
What's the most powerful passive cooling card nowadays? April 5, 2009 03:57 PM
fitting the Accelero S1 Rev.2 in ATI 4850 April 5, 2009 01:26 PM
Sapphire Radeon HD4850 512MB Graphics Card Review April 5, 2009 10:48 AM
What's the most powerful passive cooling card nowadays? April 5, 2009 08:04 AM
Sapphire HD4850 stock heatsinks? April 4, 2009 03:26 PM
X-bit labs Community :: View topic - 4850 / 4870 experiences, results. April 4, 2009 12:27 PM
Sapphire HD4850 stock heatsinks? April 4, 2009 06:25 AM
Overclockers UK Forums - View Single Post - Aftermarket Cooler For 4850 April 4, 2009 03:48 AM
4850 and in need of temperature solutions. April 4, 2009 02:39 AM
Help with installing Accelero S1 Rev 2 on a 4850 - Overclockers Forums April 3, 2009 04:15 PM
Cooler for a 4850 - Overclock.net - Overclocking.net April 3, 2009 03:30 PM
ExtremeTech Discussions - A Cooler, Quieter Radeon HD 4870 April 3, 2009 12:21 PM
NCIX.com - Buy Sapphire Radeon HD 4850 512MB GDDR3 PCI-E Video Card - 11132-11-20R In Canada. April 3, 2009 09:52 AM
HD4850 cooler. New one. - Overclock.net - Overclocking.net April 3, 2009 09:08 AM
Need a beginner's guide to replacing a graphics card Heatsink April 3, 2009 08:42 AM
How to reduce heat Ati HD 4850? - Overclockers Australia Forums April 3, 2009 02:54 AM
SweClockers.com - Forum: Accelero S1 rev2 p en 4850 - En snabb guide April 3, 2009 02:22 AM
