Categories
Review Contents:
Sapphire Radeon HD4850 512MB Graphics Card Review
by Michael "SKYMTL" Hoenig     |     July 1, 2008
Arctic Cooling MX-2 & S1 Rev.2 Installation
By now I am sure you all know that the HD4850 and HD4870 are compatible with the same heatsinks and universal (not full coverage) water blocks that the HD38xx series were. If you don’t already know this….welcome to the dark side where voiding warranties is the norm and high temperatures are a thing of the past.
Today we have something a little different for you since we have already gone through test fittings of these coolers over in our HD4870 review which can be found here: Palit Radeon HD4870 512MB Graphics Card Review. Instead, what we are doing here is a little review within a review where we will be testing two very popular products from Arctic Cooling : MX-2 thermal compound and their always-popular Accelero S1 Rev.2. It is important to note that the MX-2 was also applied to the base of the S1 during testing.
Well, let’s get to it!!
Big effing tube of MX-2, CHECK!!
Accelero S1 Rev.2 Installation
As some of you know, the Arctic Cooling S1 Rev.2 is one of the most popular GPU coolers on the market today. It offers the possibility of completely fanless cooling due to its massive surface area while also offering modders the option to mount a 120mm fan or installing the recommended Turbo Module. Sticking with Arctic Cooling’s philosophy of keeping prices down while offering superior performance, it is also one of the least expensive coolers on the market even though it does not come with a pre-installed fan.
After removing the stock cooler and the stock thermal compound, we can get to applying all the necessary ramsinks and VRM sinks. You can see above the NEW VRM sinks (the tall ones on the large inductors) which will be included with every S1 Rev. 2 produced after May 2008. There are 6 included in a package (I somehow lost the other ones, d’oh!!) so we are using low-profile Thermaltake heatsinks for the other VRM modules.
The only thing that Arctic Cooling still needs to work on is the thermal tape used on their ramsinks since it does not stick well at all. So, make sure to gently press all of the ramsinks down for about 30 seconds each to ensure they adhere properly to the ICs.
It is then a simple matter of applying the thermal compound, tightening the screws and making sure that the S1’s base makes good contact with the core. Basically, the fitment is flawless.
The only very minor issue we ran into was that due to the height of the ramsinks and the memory’s proximity to the core, the heatpipes will interfere with the outside ramsink. To alleviate this you either need to use a shorter ramsink or push the one supplied by Arctic Cooling back a bit so the heatpipe isn’t pressing down on it.
Just to make sure the S1 was applying sufficient pressure of the thermal compound and the core itself, we removed the heatsink to check if the TIM was evenly distributed over the GPU’s surface. As you can see above, it is absolutely perfect with the MX-2 spread perfectly to every corner of the core.
On the next page we take a look at the fan options and finally the performance that the Arctic Cooling S1 Rev.2 offers on this card.
Latest Reviews in Video Cards
June 3, 2009
1651The HD 4890 is ATI's bid to attack the hgh-end single GPU market and from the looks of things, they are succeeding quite well.  With board parters releasing everythi...
May 25, 2009
1138The GTX 275 was released a short while ago and while it was in short supply, it can now be found everywhere. With sales of these cards happening on a nearly weekly b...
May 7, 2009
664A few months ago, everyone was up in arms over Nvidia's choice to give the 9800 GTX+ a brand new name. What is now known as the GTS 250 had a rocky beginning but in ...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/8299-sapphire-radeon-hd4850-512mb-graphics-card-review.html
Posted By Date
silentpcreview.com | View topic - Diamond Radeon HD4850 July 1, 2009 12:04 AM
SweClockers.com - Forum: passar denna kylare på mitt HD 4850? June 28, 2009 04:15 PM
Sapphire Radeon HD4850 512MB Graphics Card Review | GPU Watch - The Latest Video Card News and Reviews June 25, 2009 05:31 PM
The Best Way To Cool Video Cards. June 25, 2009 07:28 AM
Êîÿ âèäåî êàðòà äà ñè êóïà ïëñ êàæåòå 4å ñå 4óäà - BulForum June 25, 2009 04:59 AM
powerfull silent gaming card - Monitors/Video - Whirlpool Broadband Forums June 23, 2009 05:26 AM
6000+ & 4870 cooling June 20, 2009 07:17 PM
AnandTech - 4850 cooling question June 20, 2009 05:28 PM
MWTS: Powercolor HD4850 mounted with aftermarketcooler - VR-Zone IT & Lifestyle Forum! June 19, 2009 03:31 AM
Review of Sapphire Radeon HD 4850 512MB GDDR3 PCIe 100242L, Review Sapphire Radeon HD 4850 512MB GDDR3 PCIe 100242L - PCI-Express - Page 2 of 3 June 17, 2009 05:24 PM
.:: OC-Lab Forum ::. • View topic - Uradna tema - ATi Radeon HD 4000 June 17, 2009 02:29 AM
best air cooler for HD 4850? - Page 3 - Overclock.net - Overclocking.net June 15, 2009 07:26 PM
[Topic Unique] Refroidissement alternatif pour CG - Page 9 - Canardpc.com June 12, 2009 11:28 AM
Âñè÷êî çà Radeon HD4850 - Ñòðàíèöà 25 - hardwareBG.com ôîðóì June 11, 2009 01:39 PM
Need a beginner's guide to replacing a graphics card Heatsink June 11, 2009 07:02 AM
Sapphire Radeon HD4850 512MB Graphics Card Review June 7, 2009 08:50 AM
.: el Canto de los Duendes :. - photos from tomdan - Fotolog June 4, 2009 04:26 PM
?????? ??? ??????!!! - ADSLgr.com June 4, 2009 05:01 AM
Asus EAH4850 (ATI HD4850) - HardwareLogic June 3, 2009 04:33 AM
HD 4850 | GPU Watch - The Latest Video Card News and Reviews May 30, 2009 09:27 AM
Where is the Sapphire HD 4850 100242? - XtremeSystems Forums May 29, 2009 04:54 AM
A few questions... - Page 2 - Overclock.net - Overclocking.net May 28, 2009 12:25 PM
I guess the 4770's are a pretty hot item. - Rage3D Discussion Area May 28, 2009 11:34 AM
Which aftermarket cooler for 4870? - Overclockers UK Forums May 27, 2009 07:07 PM
SweClockers.com - Forum: Hjälp med montering av kylare [Bilder] May 25, 2009 10:22 AM
Going to mod my 4850, will these parts work? May 25, 2009 03:18 AM
Help me, new 4850, new cooler, or nVidia? May 22, 2009 08:08 AM
4850 - The noise is driving me mad. - Overclockers UK Forums May 22, 2009 03:34 AM
The Best Way To Cool Video Cards. May 21, 2009 11:34 PM
fitting the Accelero S1 Rev.2 in ATI 4850 May 20, 2009 05:24 PM
powerfull silent gaming card - Monitors/Video May 18, 2009 04:24 PM
Incredible: 4770 in XFire beats 4890 AND it's cheaper !!! - Page 3 - techPowerUp! Forums May 18, 2009 06:24 AM
passar en accelero S1 rev2 på ett hd 4850 ? - Minhembio forum May 16, 2009 04:30 PM
La 4850 dual slot de Sapphire et le silence - Canardpc.com May 14, 2009 11:25 AM
Slo-Tech | Test 4850 ter 3870 May 13, 2009 02:27 AM
ணஹ௮ ÚÑÈ ÌíÌÇ ßãÈíæÊÑ ãæá.ÇÓÚÇÑ ÇáÞØÚ..ÊÌãíÚ ÇÌåÒÉ..ãÚáæãÇÊ Úä ÞØÚ ௮ஹண - ÇáÕÝÍÉ 199 - ãäÊÏíÇÊ ÚÑÈ ÌíÌÇ ÈÇíÊ May 11, 2009 10:48 AM
Help me, new 4850, new cooler, or nVidia? May 8, 2009 11:39 AM
6000+ & 4870 cooling April 28, 2009 05:33 AM
Chieftec 400w (Ku?i?ta i napajanja) @ Bug Online Forum April 27, 2009 08:15 AM
Best cooling for ATI HD4850 - Page 3 - XtremeSystems Forums April 27, 2009 06:24 AM
[VENDO] HD4850 + acelero s1 rev2 - Página 3 - 3DG April 23, 2009 06:17 AM
Arctic Cooling Accelero S1 Rev. 2 review door F for Fragging | Tweakers.net Productreviews April 21, 2009 08:47 AM
AnandTech - accelero s1 nsk2400 April 21, 2009 07:13 AM
Untitled document April 19, 2009 01:51 PM
Which ATI 4850 graphics card should I buy? - Yahoo! UK & Ireland Answers April 19, 2009 11:44 AM
4850 and in need of temperature solutions. April 16, 2009 09:13 AM
Better video playback with the Radeon HD 3850? - Open Tech Support Community April 15, 2009 01:14 PM
AnandTech - Underclocking the 4850 April 15, 2009 11:58 AM
AnandTech - HD4850/4870 Aftermarket Coolers April 13, 2009 04:18 PM
Il mio pc April 12, 2009 02:06 PM
ATI HD 4850? - Mobile-Review.com Forums April 12, 2009 12:48 AM
Silent GPU for $200 April 10, 2009 03:06 PM
TR Forums • View topic - HD4850 Goes From 88C to 39C Using Accelero S1 April 10, 2009 11:43 AM
Aftermarket Cooler For 4850 - Page 2 - Overclockers UK Forums April 10, 2009 06:22 AM
Which ATI 4850 graphics card should I buy? - Yahoo! Answers April 10, 2009 05:21 AM
Sapphire Radeon HD4850 512MB Graphics Card Review April 8, 2009 09:01 AM
Radeon HD 4850 or 9800 GT - Page 4 - Overclock.net - Overclocking.net April 8, 2009 04:00 AM
4850 with Zalman VF900? - [H]ard|Forum April 7, 2009 07:36 PM
HD 4850 - ref cooling and Rivatuner 2.10 - Monitors/Video April 7, 2009 10:26 AM
Accelero S2 and 4850? - [H]ard|Forum April 7, 2009 08:42 AM
Diamond Radeon HD4850 | silentpcreview.com April 6, 2009 09:14 PM
AnandTech - 4850 is crashing at stock: I think I've isolated the naked VRMs as the culprit... April 6, 2009 04:34 PM
silentpcreview.com | View topic - HD 4850: Ethics, Warranties, and Aftermarket Coolers April 6, 2009 01:52 PM
Sapphire Radeon HD4850 512MB Graphics Card Review - Madshrimps Forum Madness April 6, 2009 05:58 AM
Going to mod my 4850, will these parts work? April 6, 2009 03:16 AM
HD 4850 Naked (New Cooler added) Zalman VF900 CU - Page 2 - techPowerUp! Forums April 6, 2009 01:45 AM
Neue Benchmarks von 4850/4870 vs. GTX280 und Co. | New benchmarks of 4850/4870 vs. GTX280 and co. - News Archiv - ATi-Forum.de April 5, 2009 04:58 PM
What's the most powerful passive cooling card nowadays? April 5, 2009 03:57 PM
fitting the Accelero S1 Rev.2 in ATI 4850 April 5, 2009 01:26 PM
Sapphire Radeon HD4850 512MB Graphics Card Review April 5, 2009 10:48 AM
What's the most powerful passive cooling card nowadays? April 5, 2009 08:04 AM
Sapphire HD4850 stock heatsinks? April 4, 2009 03:26 PM
X-bit labs Community :: View topic - 4850 / 4870 experiences, results. April 4, 2009 12:27 PM
Sapphire HD4850 stock heatsinks? April 4, 2009 06:25 AM
Overclockers UK Forums - View Single Post - Aftermarket Cooler For 4850 April 4, 2009 03:48 AM
4850 and in need of temperature solutions. April 4, 2009 02:39 AM
Help with installing Accelero S1 Rev 2 on a 4850 - Overclockers Forums April 3, 2009 04:15 PM
Cooler for a 4850 - Overclock.net - Overclocking.net April 3, 2009 03:30 PM
ExtremeTech Discussions - A Cooler, Quieter Radeon HD 4870 April 3, 2009 12:21 PM
NCIX.com - Buy Sapphire Radeon HD 4850 512MB GDDR3 PCI-E Video Card - 11132-11-20R In Canada. April 3, 2009 09:52 AM
HD4850 cooler. New one. - Overclock.net - Overclocking.net April 3, 2009 09:08 AM
Need a beginner's guide to replacing a graphics card Heatsink April 3, 2009 08:42 AM
How to reduce heat Ati HD 4850? - Overclockers Australia Forums April 3, 2009 02:54 AM
SweClockers.com - Forum: Accelero S1 rev2 på en 4850 - En snabb guide April 3, 2009 02:22 AM
