Categories
Review Contents:
Palit Radeon HD4870 512MB Graphics Card Review
by Michael "SKYMTL" Hoenig     |     June 25, 2008
Under the Heatsink
Please note that removing the heatsink will void the warranty on your card.
Click on images for larger version
Removal of the HD4870 heatsink is very straightforward and once it is eased off we have a good view of what makes this card tick. As already mentioned, the PCB layout is extremely clean with all of the power distribution pushed to the back of the card while around the core there are the traces which go to and from the GDDR5 memory. Since all of the decoding and I/O functions are controlled on the R770XT chip, there is no need for additional chips spread throughout the PCB like the NVIO chip used on the Nvidia GTX 280.
The power distribution and voltage regulation area of the HD4870 is a confusing labyrinth of VRMs chokes, resistors and transistors. Interestingly, there are only five small VRMs which had thermal pads placed on them which means that the larger power components do not need additional cooling.
Additional voltage regulation is done by a large Vitec 59PR9853 multi-phase inductor as well as a pair of smaller Pulse VRM modules. Due to their temperature tolerances (up to 125C) they do not need any additional cooling since their large surface area distributes most of the heat they generate. It also looks like the Vitec module can be upgraded to a higher-capacity unit since there are two additional solder points left open.
The R770XT core is not covered by an IHS like some Nvidia cards but rather its polished surface makes direct contact with the underside of the heatsink. It is also surrounded by a metal shim which keeps it in place and secured to the PCB. What struck us as interesting was how SMALL this core is for the amount of transistors it packs.
The memory used on the HD4870 is the next generation GDDR5 memory from Qimonda. Unfortunately, at the time of this review there hasn’t been any spec sheets put up so other than knowing that the two banks each operate at 1800Mhz DDR (for an effective speed of 3.6Ghz DDR) on this card, there isn’t much other info.
The underside of the heatsink makes contact with the ram modules through a pair of thermal pads while the VRMs have their own separate pad used to transfer the heat they produce. Meanwhile, the base is of surprisingly good quality aside from a few tooling marks and scratches.
Latest Reviews in Video Cards
June 3, 2009
1651The HD 4890 is ATI's bid to attack the hgh-end single GPU market and from the looks of things, they are succeeding quite well.  With board parters releasing everythi...
May 25, 2009
1138The GTX 275 was released a short while ago and while it was in short supply, it can now be found everywhere. With sales of these cards happening on a nearly weekly b...
May 7, 2009
664A few months ago, everyone was up in arms over Nvidia's choice to give the 9800 GTX+ a brand new name. What is now known as the GTS 250 had a rocky beginning but in ...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/8162-palit-radeon-hd4870-512mb-graphics-card-review.html
Posted By Date
What's your experience with the heat of a 4850? - Page 2 - Overclockers UK Forums Yesterday 03:06 PM
How long till 4870's get enhanced cooling solutions? June 27, 2009 08:11 PM
SweClockers.com - Forum: HD4870 reviews. [Lista] June 27, 2009 12:27 PM
AMD Processors Forums - AMD Phenom II 720 X3 June 27, 2009 12:02 PM
AnandTech forums -- Search Results June 26, 2009 02:27 PM
PC Perspective - News Archive June 25, 2009 06:44 PM
4870ζȴÓ55/82µ½¡¡33/43¡¡Ô­×°·çÉÈÕæ´Î - ÏÔ¿¨ÊÓÏñ¼¼Êõ¼°ÐÐÇé×ÊѶÌÖÂÛÇø - µçÄÔÓ²¼þÐÂÉúÍøÉçÇø - ¹úÄÚ×îºÃµÄµçÄÔÓ²¼þ½»Ò×¼°¶þÊÖÖû»»¥¶¯Æ½Ì¨ June 25, 2009 08:33 AM
GPU Price chart-Updated Weekly! - nV News Forums June 25, 2009 04:58 AM
How to remove ram sinks HR-03 GT? - Page 2 - Futuremark / YouGamers Forums June 22, 2009 11:57 AM
AMD Game Forums - Advice Needed on HIS ATI Radeon HD 4870 512MB GDDR5 PCI-Express Graphics Card June 17, 2009 07:47 AM
Trying to make the most inexpensive gaming PC possible (sub-$350). June 15, 2009 07:33 AM
HD 4850 cooling options? - Rage3D Discussion Area June 12, 2009 01:24 AM
Thinking about building a computer. Quick Question. June 8, 2009 06:03 PM
Benchmark ATI Radeon HD 4870 June 7, 2009 11:20 PM
New (first) build, comments appreciated June 7, 2009 07:49 PM
GameSpot Forums - PC Hardware Discussion - Anandtech reviews the HD4870 June 7, 2009 03:56 AM
Ôîðóìû Modlabs.net > Ñìåíà îõëàæäåíèÿ HD4870 June 6, 2009 10:52 PM
Whats Power Supply do i need for this setup???? June 5, 2009 10:51 PM
Whats Power Supply do i need for this setup???? June 5, 2009 02:31 PM
DarkHardware • Diziyi görüntüle - HD 4870 ... June 5, 2009 01:00 PM
Which non-reference 4850 card do you think is better? June 4, 2009 12:34 AM
Overclockers Australia Forums - View Single Post - ATI Radeon HD 4000 Series | 4870X2 4870 4850 4600 | Reviews | Discussion | See OP!! May 31, 2009 04:07 AM
Is this really a 4870? May 29, 2009 09:30 AM
AMD strikes again with the Radeon HD 4870 :: TweakTown May 28, 2009 01:38 AM
Which aftermarket cooler for 4870? - Overclockers UK Forums May 27, 2009 07:07 PM
Futuremark - News - Newsarticle May 26, 2009 09:59 AM
ATi Radeon 4870 Questions and Info - Overclock.net - Overclocking.net May 25, 2009 10:25 AM
Hd 4870 Vs Hd 4870 - Discharged May 25, 2009 02:33 AM
Palit Radeon HD4870 512MB Graphics Card - PCSTATS.com May 23, 2009 11:07 AM
Palit Radeon HD4870 512MB Graphics Card Review May 23, 2009 11:01 AM
does thermaltake duorb work with hd 4850? May 23, 2009 02:25 AM
Dilemne hd 4850 / 4870 /4870 x2 - Matriel Informatique sur JeuxVideo.com May 23, 2009 12:58 AM
upgrade to 4850 from 8800 GTS 320 mb worth it? - Page 4 - Age of Conan Forums May 21, 2009 06:12 AM
My 4870 has arrived: Picture, overclocking/benching soon! - Page 7 - [H]ard|Forum May 17, 2009 05:40 PM
GameSpot Forums - PC Hardware Discussion - RADEON 4870 reviews galore! May 14, 2009 12:56 PM
Official ATi 4850 and 4870 series review thread! - Page 7 - nV News Forums May 10, 2009 08:15 PM
Quiet PC Forums • View topic - Club3D 4870 1GB Overclocked Edion? May 10, 2009 05:42 AM
hard-h2o.com :: Revisar tema - Asus 4870 vs sapphire 4870 - temperatura May 9, 2009 01:59 PM
NCIX.com - Buy Palit Radeon HD 4870 512MB GDDR5 PCI-E 2XDVI-I Video Card - AE=48700+T352 In Canada. May 9, 2009 12:39 AM
Looking for a cooler for the HD 4800 series.. May 7, 2009 10:46 AM
Palit Radeon HD4870 512MB Graphics Card Review @ Hardware Canucks May 5, 2009 01:58 PM
Recensioni ATI Radeon HD 4870/4850 • Dinox PC May 2, 2009 11:06 AM
HardwareOnline.dk - Forum: 550W til GTX285 nok? May 2, 2009 07:37 AM
Wednesday Shortbread - The Tech Report April 29, 2009 11:53 PM
Need to buy ne cooling [VERY URGENT] - PC Peripherals - TechEnclave April 29, 2009 07:20 AM
Zalman VF1000 LED review door snowmanappie | Tweakers.net Productreviews April 29, 2009 02:08 AM
Complete List of HD4870 & HD4850 Review April 28, 2009 10:22 PM
SweClockers.com - Forum: Färska tester avslöjar Radeon HD 4870 April 28, 2009 09:33 AM
Power Supply for my 4870? - [H]ard|Forum April 27, 2009 11:49 AM
Ati 4870 Aftermarket Coolers - Computer Juice - Forums April 26, 2009 11:54 AM
Check this out (best for you $ by far!)ATI 4870 - Age of Conan Forums April 26, 2009 07:20 AM
ATI HD4800 Review Thread - XtremeSystems Forums April 25, 2009 06:53 PM
4870 Vs 4850 Differences - Neowin Forums April 24, 2009 04:26 PM
Official ATi 4850 and 4870 series review thread! - nV News Forums April 24, 2009 02:11 PM
8800GTS to 4870? - Overclock.net - Overclocking.net April 24, 2009 05:55 AM
Gentlemen I give you the best 4850 cooler for you. - Facepunch April 23, 2009 09:35 AM
looking for the best cooler to the 4870 - XtremeSystems Forums April 23, 2009 01:27 AM
4870 vs 4870 - Kustom PC's Forums April 21, 2009 02:57 PM
ATI vs nVidia April 18, 2009 09:43 PM
Dual slot cooler third party for 4850? - Overclockers Forums April 18, 2009 01:17 AM
Radeon HD 4870 Reviews Roundup | The Geeks Of 3D - 3D Tech News April 17, 2009 07:23 AM
Accelerated Video Transcoding(AVT) on HD4800 series, where is it ? - [H]ard|Forum April 17, 2009 12:12 AM
Sapphire HD4870 o XFX 9800GTX XT? April 15, 2009 10:24 AM
EXPIRED - Thermalright HR-03-GT VGA cooler (Ideal for 8800GT) £29.88 Delivered @ Scan - Page 2 - HotUKDeals Forum April 15, 2009 04:57 AM
GameSpot Forums - PC Hardware Discussion - Recommendations on ATi aftermarket coolers April 13, 2009 06:47 PM
Sapphire 4870 ordered - nV News Forums April 13, 2009 01:35 PM
AnandTech - HD4850/4870 Aftermarket Coolers April 12, 2009 03:09 PM
Watercooling the 4870 - Overclockers Forums April 12, 2009 04:24 AM
4870 Aftermarket HSF question - [H]ard|Forum April 12, 2009 03:08 AM
Hardware - Radeon HD 4870 GeForce GTX 260: NVIDIA? | Overclockers.com.ua April 11, 2009 10:29 PM
4850 - Stock vs. Accelero vs. DuOrb vs. vf900 - Overclockers UK Forums April 11, 2009 02:06 AM
AnandTech: NVIDIA's First 55nm GPU: GeForce 9800 GTX+ Preview April 11, 2009 12:27 AM
Quad CFX 4870 GDDR5 foto :) - Pagina 2 | Forum -X- NextHardware April 10, 2009 05:20 PM
Asus 4870 vs sapphire 4870 - temperatura April 10, 2009 05:31 AM
EXCLUSIVE!!!!! Review 4870 - OVERCLOCKZONE Forums April 9, 2009 08:41 PM
Is this really a 4870? April 9, 2009 06:43 PM
4870 aftermarket cooling: GIANT temp. difference = high overclock? - [H]ard|Forum April 9, 2009 11:10 AM
Sapphire HD4850 512 Mb - [NEWS] | Forum -X- NextHardware April 8, 2009 05:54 AM
4800 Series reviews!!!!!!! April 8, 2009 03:47 AM
AnandTech - ATi 4870/4850 Review Thread April 7, 2009 10:09 PM
4870 Review - Age of Conan Europe Forums April 7, 2009 02:42 PM
techPowerUp! :: Review Database April 7, 2009 02:33 PM
4870 coolers that fit & temps - Overclock.net - Overclocking.net April 7, 2009 11:48 AM
Accelerated Video Transcoding(AVT) on HD4800 series, where is it ? - techPowerUp! Forums April 7, 2009 11:27 AM
Review 4850 y 4870 - Foros de CHW April 7, 2009 05:00 AM
AnandTech - GPU acceleration for video encoding on 4850 April 6, 2009 08:25 PM
silentpcreview.com | View topic - Where to get Accelero S1 VRAM heatsinks April 6, 2009 07:27 PM
HD4870 Reviews In One Place - Overclock.net - Overclocking.net April 6, 2009 05:08 PM
Arctic Cooling Accelero S1 Rev.2 @ [H] - Page 4 - [H]ard|Forum April 6, 2009 04:16 PM
ATI 4870 1GB? April 6, 2009 03:58 PM
4870 is a watt-hog - Overclockers Forums April 6, 2009 11:45 AM
ATI 4870 1GB? April 6, 2009 05:41 AM
Reviews Radeon HD 4870 around The Web - MadBoxpc.com April 6, 2009 01:39 AM
Thermalright Aftermarker Cooler 4870 - [H]ard|Forum April 5, 2009 11:32 PM
ATI 4850 discussion,tweaks & Info - NAG Online Forums April 5, 2009 08:22 PM
HCµÄ4870ÆÀ²â³öÀ´ÁË¡£ - ¡îPCIÍõÅÆÏÔ¿¨ÊÓÏñ¼¼ÊõÌÖÂÛÇø - µçÄÔÓ²¼þÐÂÉúÍøÉçÇø - ¹úÄÚ×îºÃµÄµçÄÔÓ²¼þ½»Ò×¼°¶þÊÖÖû»»¥¶¯Æ½Ì¨ April 5, 2009 07:57 PM
After-market coolers for the 4870 - techPowerUp! Forums April 5, 2009 07:29 PM
AMDZone.com • View topic - Radeon 3870/4850 waterblock compatibility April 5, 2009 06:32 PM
DailyTech - 6/25/2008 Daily Hardware Reviews -- ATI Radeon HD 4870 Edition April 5, 2009 06:01 PM
ATi HD Radeon 4850, 4870 based on RV770 Prt2 - Monitors/Video - Whirlpool Broadband Forums April 5, 2009 05:34 PM
What coolers to go on a 4870 1gb - Overclockers UK Forums April 5, 2009 02:52 AM
Best HD3870/4870 Cooler - bit-tech.net Forums April 5, 2009 12:36 AM
ATI Radeon HD 4850 and 4870 reviewed: all that and a bag of RV770 chips April 4, 2009 11:47 PM
4870 Aftermarket Cooling Options - [H]ard|Forum April 4, 2009 07:10 PM
AnandTech - HD Encoding/Transcoding with HD 4800 April 4, 2009 04:58 PM
EXPIRED - Thermalright HR-03-GT VGA cooler (Ideal for 8800GT) £29.88 Delivered @ Scan - HotUKDeals Forum April 4, 2009 01:08 PM
Upgrade from 8800GT to HD4870? April 4, 2009 07:01 AM
cual es el mejor disipador-ventilador para la ati 4870 April 4, 2009 06:14 AM
accelero rev 2 vs HR-03 on the ati 4870 - Overclock.net - Overclocking.net April 4, 2009 05:58 AM
does thermaltake duorb work with hd 4850? April 4, 2009 04:16 AM
[HC] Palit 4870 Benchmark review - Overclock.net - Overclocking.net April 4, 2009 01:38 AM
Video editing minimum requirements? - MajorGeeks Support Forums April 3, 2009 07:06 PM
8800gt vs 4870 at 1920x1200 - Overclock.net - Overclocking.net April 3, 2009 02:51 PM
MOD-PC.com - Ati Radeon HD4850 y HD4870 - Hardware, Overclocking y Refrigeración April 3, 2009 12:31 PM
Better cooling for 4850/4870? April 3, 2009 11:37 AM
4870 and HR-03-GT are they compatible? - HEXUS.community discussion forums April 3, 2009 03:36 AM
After market coolers for 4870 - techPowerUp! Forums April 3, 2009 02:45 AM
Swiftech Waterblock for new ATi hd 4850/4870 - Overclock.net - Overclocking.net April 3, 2009 12:41 AM
Upgrade from 8800GT to HD4870? April 2, 2009 09:43 PM
HD 4870 vs. GTX 260 and GTX 280 Review, Benches ... - PC Perspective Forums April 2, 2009 08:39 PM
Better cooling for 4850/4870? April 2, 2009 04:41 PM
4870 silent aftermarket cooler? - Beyond3D Forum April 2, 2009 03:34 PM
Best aftermarket cooler for 4850/4870? - [H]ard|Forum April 2, 2009 02:59 PM
Recommended HD 4870 cooler? - Guru3D.com Forums April 2, 2009 02:05 PM
ATI Radeon 4870/4850 Aftermarket Cooler Compatibility - nV News Forums April 2, 2009 01:58 PM
