Categories
Review Contents:
ASRock X48TurboTwins-WiFi Motherboard Review
by Eldonko     |     June 30, 2008
BIOS Rundown
The true test of a motherboard for an overclocker or computer enthusiast is not usually board accessories or features, it is the BIOS and the ability for the board to handle a decent overclock. We will take a closer look at the overclockability of the board in the overclocking section.
The ASRock X48TurboTwins-WiFi features an AMI 8mb BIOS and supports ACPI 1.1 Compliance Wake-up Events. The splash screen upon POST was pleasing to the eye and ASRock included a few other splash screen options selectable in the boot section of the BIOS. One point to note is you must press F2 instead of the typical delete key to enter the BIOS upon booting. Seems strange to move from the standard delete key, but it is not an issue if users are aware of it.
The PC Health page was consistent with many other boards, showing CPU and motherboard temperatures, fan speeds for the two fan headers, and voltages (vcore, 3.3v, 5.0v, and 12.0v). It would have been nice to see Vdimm and a chipset monitoring setting but this of course could mean a more expensive monitoring chip.
The BIOS info page is also typical of many other boards on the market. This page shows which CPU and memory is installed and a few specifications such as cache and speed. Also, if you aren’t sure which BIOS version is installed, the BIOS info page indicates the current BIOS version.
The CPU Configuration page includes CPU Thermal Throttling and Intel Speedstep Technology, both of which are recommended to disable if you want the multi to remain static. This is also the screen where you will find adjustable frequencies for CPU / PCIE and the CPU multiplier. Users must set Overclock Mode to Manual to adjust these settings.
The available RAM timings are as basic as it gets with the common four tCL, tRCD, tRP, tRAS plus DRAM Command Rate (1N vs. 2N). This is one of the biggest issues we had with the BIOS as secondary memory tweaking is important to be able to boot at particular memory dividers and chipset straps. Also, for memory dividers there are only three available: 400Mhz (DDR3 800), 533Mhz (DDR3 1066), and 667Mhz (DDR3 1333). We will go over how the dividers work in detail in the overclocking section.
Another feature on the Chipset Settings screen that you will see in X48 chipset boards is XMP Technology. XMP (extreme memory profile) is Intel compatible and provides the next level of JEDEC standard. Briefly, XMP is an extra speed bin to JEDEC’s standard DDR3’s definitions, allowing for higher speeds and tighter timings than JEDEC, simply by enabling the XMP Profile.
Continuing down the Chipset Settings screen, we see all of the voltages needed for overclocking. At default all of the settings are set to auto, which provides stock voltages for each component.
The maximum CPU voltage on the board is 1.60v, and unlike most other settings that have a drop-down menu and allow easy voltage selections, the only way to adjust CPU voltage is by pressing + and – on the keyboard. This method is not as convenient and it takes extra time to adjust CPU voltage. DRAM voltage is selectable to 2.40v and should be more than enough voltage for any DDR3 modules on the market.
Northbridge, Southbridge, and VTT Reference voltages are not in fact numeric selectable voltages but rather settings of low, medium, high, and very high. It is a little concerning to not be aware of how much voltage is actually being used in each of the settings and it is recommended to avoid the highest setting altogether to be safe and not risk damaging an expensive CPU. This is especially important for VTT voltages as several users have reported dead 45nm CPUs at only 1.5v VTT. After asking several times, ASRock support was not able to provide any actual voltages for these settings nor measure points for a digital multimeter.
One bright point in the voltage section however is instead of using non-numerical settings for GTLREF Voltage, ASRock added options ranging from 0.67 x VTT to 0.614 x VTT, which eliminates the grey area and is quite handy for FSB overclocking.
All in all, the BIOS on this board should appeal to novice overclockers since all of the basic adjustments for minor to mid-range overclocks are there but to be honest, there is isn't much for the enthusiast here. What we do like to see is that ASRock is taking steps for their boards to appeal to a wider market; as more boards come out the BIOS seems to be becoming more and more overclocker friendly. Hopefully with the next board ASRock will add more secondary memory timings, more memory dividers, and actual voltages for NB, SB, and VTT as these are the types of things enthusiasts demand in a good overclocker’s board.
October 30, 2008
The P45 is possibly the most popular chipset on the market and Gigabyte has been using it on an amazing number of boards as of late. The EP45-UD3P is their latest b...
October 20, 2008
DFI has always lead the way when it comes to enthusiast motherboards but this time they are trying out something a bit different: an mATX board with the overclocking...
September 3, 2008
The ASUS Rampage Extreme has been setting overclocking world records from the day it was put into the hands of enthusiasts. In this review we take a look at not onl...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/8082-asrock-x48turbotwins-wifi-motherboard-review.html
Posted By Date
[OC]ModShop - ASRock X48TurboTwins-WiFi motherboard November 4, 2008
ÿÈÕÈ«ÇòIT²âÊÔËٵݣºÍ¸ÊÓ9800GTX+¡ªÐ¡ÐÜÔÚÏß¡ªÏÔ¿¨ÆµµÀ October 15, 2008
Rate/Review this build please - Page 2 - Overclock.net - Overclocking.net October 13, 2008
GA-X48T-DQ6 or GA-X48-DQ6??? - PC PowerPlay Forums October 12, 2008
CPU Speed Wall? What's Killing My OC? - Overclock.net - Overclocking.net September 27, 2008
Game-pc 1500€ - Forum Azerty Hardware August 18, 2008
Futuremark - News - Newsarticle July 24, 2008
ASRock Motherboard - Product - X48TurboTwins-WiFi - Awards July 22, 2008
ITProPortal.com - ASRock X48TurboTwins-WiFi DDR2 / DDR3 Motherboard Review July 22, 2008
The Motherboard Reviews - Forums on the BleedinEdge July 22, 2008
DailyTech - 6/30/2008 Daily Hardware Reviews July 20, 2008
PC Perspective - News Archive July 19, 2008
techPowerUp! - The latest in hardware and gaming July 19, 2008
PCSTATS.com - Get The 'Stats and Stay Informed! Hardware Comparsion HQ July 19, 2008
ASRock X48TurboTwins-WiFi Motherboard Review - Futuremark / YouGamers Forums July 19, 2008
?????????? July 18, 2008
ASRock Motherboard - Product - X48TurboTwins - Awards July 18, 2008
ASRock Motherboard - News July 17, 2008
AsRock X48 Turbo Twins-WiFi Available NOW! - XtremeSystems Forums July 17, 2008
ASRock X48TurboTwins-WiFi Motherboard Review - Madshrimps Forum Madness July 17, 2008
ASRock X48TurboTwins-WiFi motherboard - PCSTATS.com July 17, 2008
?????????? July 17, 2008
ITProPortal.com - ASRock X48TurboTwins-WiFi DDR2 / DDR3 Motherboard Review July 16, 2008
ASRock X48TurboTwins-WiFi Motherboard Review @ Hardware Canucks July 16, 2008
ASRock, WiFi anywhere! July 16, 2008
