Categories
Review Contents:
Xigmatek HDT-S1283 CPU Cooler Review
by AkG     |     June 19, 2008
Conclusion
The Xigmatek HDT-S1283 really does prove that more heatpipes and more weight is not needed since from a performance point of view it has heralded in a new cooling era as it is simply in a league of its own. It easily leaves bigger, heavier and above all else more costly coolers in its dust. Why would anyone want to stick a full kilogram of copper onto their motherboard when almost half that will give you just as good results?
Unfortunately, not everything is perfect with this unit. By relying on plastic pins, we feel that Xigmatek has really limited its true potential and it is a crying shame such a kick ass cooler is hobbled with such a cheesy mounting setup. Worse still is the fact that its fan installation process can be considered truly frustrating; however the HDT-S1283 actually has the cooling potential to make up for its prima-donna ways.
If you are like us and don’t trust 600 grams to four little push pins, Thermalright makes a very good conversion kit that will change this cooler from pushpins to a screw and backplate system for about 10 bucks. To us this would be money wisely spent and it more than likely would translate into even better results. As already mentioned, we were not too fond of the fan mounting system, since even if you do end up mounting the fan the way we recommend this setup still leaves a good-sized gap between the fan and the heatsink. We believe if Xigmatek had gone for a normal friction style mount it would have increased the cooling potential (as no air would have escaped through this gap) and the CPU numbers would have been even lower. Another minor quibble we have with this unit is we have to wonder how much better this cooler would have been if its face was as good as the Noctua’s we tested a while ago. To us if you take the mounting system of the Noctua and the front face from the Noctua and combine it with the Xigmatek HDT-S1283, you would have the best cooling solution available in terms of performance and ease of installation
In the end the HDT-S1283 has a lot going for it, and has very few negatives. We hope that future revisions will fix these little things and turn this from a very good cooler at a great price into a great cooler at an amazing price. For this reason we believe that this cooler is a Dam Good Value and should be at the top of your short list.
Pros:
- Amazing dual and quad cooling performance
- Quite fan
- HDT base works as advertised
- Great price
- Tool-less installation
Cons:
- Plastic mounting system
- Short warranty
- Fan installation may make you feel like a tool
Thanks to Xigmatek for sending us this product for review
Latest Reviews in Cooling
June 8, 2009
1857Lately, the CPU cooler marketplace has become cluttered with countless products that all seem to promise the same things:  performance, silence and value.   Cooler M...
May 18, 2009
673Even though the high-end air cooling market is cluttered with pretenders, every now and then a heatsink comes along which causes up to stand up and take notice. A fe...
May 4, 2009
661After we reviewed the Cooler Master V10 a while ago, we were anxious to get our hands on its little brother: the award-winning V8. Not only has this cooler won numer...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/7971-xigmatek-hdt-s1283-cpu-cooler-review.html
Posted By Date
How to apply Thermal Compound - Neowin Forums June 29, 2009 01:04 PM
Preocupación .... - HardLimit June 20, 2009 12:16 PM
Quando o tempo aquece ... qual escolher ? - Page 2 - Forum AquaPC June 20, 2009 06:25 AM
Xigmatek HDT-S1283 Heat-pipe Direct Touch CPU Cooler for Intel/AMD Products Model: HDT-S1283 [HDT-S1283] : Performance-PCs.com, ... sleeve it and they will come May 31, 2009 08:04 PM
Enthusiast Hardware News and Niche Market Hardware Guide - Ninjalane.com May 31, 2009 12:33 PM
SweClockers.com - Forum: CPU-kylare till Q6600 överklockning May 30, 2009 04:19 AM
please help with E8400 temperatures - Overclock.net - Overclocking.net May 23, 2009 06:53 PM
NCIX.com - Buy Xigmatek HDT-S1283 Direct Touch 3 Heatpipe Heatsink AM2 LGA775 S754 S939 S940 W 120MM PWM Fan - HDT-S1283 In Canada. May 20, 2009 09:15 PM
» Xigmatek HDT-S1283 CPU Cooler Review May 5, 2009 09:30 AM
XIGMATEK HDT-S1283 or Noctua NH-U12P? - Overclock.net - Overclocking.net April 20, 2009 04:38 AM
Untitled document April 12, 2009 07:12 PM
TRUE vs. Noctua NH-U12P vs. Xigmatek Dark Knight review - Page 11 - Overclock.net - Overclocking.net April 7, 2009 11:19 AM
Best CPU cooler for q6600 - techPowerUp! Forums April 5, 2009 02:21 PM
Xigmatek HDT-S1283 - High Temps - Page 2 - Overclock.net - Overclocking.net April 3, 2009 11:32 PM
Xigmatek HDT-S1283 CPU Cooler Review - Madshrimps Forum Madness April 3, 2009 08:58 AM
XIGMATEK April 3, 2009 07:54 AM
techPowerUp! :: Review Database April 3, 2009 03:28 AM
NCIX.com - Buy Xigmatek HDT-S1283 Direct Touch 3 Heatpipe Heatsink AM2 LGA775 S754 S939 S940 W 120MM PWM Fan - HDT-S1283 In Canada. April 2, 2009 04:29 PM
