| by 3oh6 | June 10, 2008 | ||
| Test Setup & Software Test Setup & Software Test Platform:
As with the last motherboard review, all testing will occur in an open bench setup to ensure complete control over motherboard and component cooling. The image to the right is an accurate portrayal of how the setup remained throughout testing. The 120mm fan was angled to cool the memory but also provided a bit of support to the chipset cooling on the motherboard. ![]() Continuing forward, we will take a quick look at the software that comes with the P5E3-Premium with a particular interest in the WIFI capabilities of this twin antenna setup. The initial ASUS software is un-changed from those of the past and is very straight forward. There are a couple tabs along the top of a small window and the options listed for each tab on the page. There were no issues to note when installing the standard drivers like the Intel chipset, network controllers, or the audio drivers. Everything installed smoothly and the next item we wanted to look at was the WiFi-AP Solo @n, which is just a long name for wireless software. ![]() The above sequence is that of switching from the original Client mode that we find ourselves in after the software installs. Setting up WEP as well as manual IP and DNS was very easy and within a minute or two we found our private SSID and were online and surfing our network. It was then time to switch to AP mode which was no more than a click of the mouse away. ![]() This is just a quick look at the wireless connection in client mode connecting to said D-Link wireless router at the 54Mbps G standard showing the full 1200KBps download speed from some NVIDIA servers. This is the maximum download speed available on our network, wireless or wired. The overall latency was quite good and there were no real issues found when working in any of the wireless modes. The option for turning the ASUS P5E3-Premium into an Access Point is a unique feature and not likely one widely utilized but a nice little feature we found fun. Being the new draft N is even better, we are sorry we weren't able to test properly with a matching wireless N router. | ||
