Quantcast
Razer Introduces Nommo Speaker Line
by MAC     |     January 9, 2018
Further expanding their reach into every corner of the PC gaming accessories market, Razer has just announced a new speaker line. Known as the Nommo series, the lineup is comprised of three models: Nommo Pro, Nommo Chroma, and Nommo.
While aesthetics were clearly a high priority, Razer claim that the Nommo speaker range was principally engineered to excel at positional audio; using left and right stereo imaging to help ensure gamers know where sounds are coming from.
The Nommo Pro is the highest-end model in the series. It is a 2.1 speaker system that has been THX Certified and that also features Dolby Virtual Speaker, which allows stereo speakers to mimic a virtual surround sound. This flagship model feature two 3-inch kevlar-coated drivers, two independent 0.8-inch silk dome tweeters, a standalone 6-inch downward firing subwoofer, and a control pod. The control pod not only serves as the volume knob, but it also houses the USB, Optical, Bluetooth, 3.5mm aux-in and 3.5mm headphone jack. Unsurprisingly, the speakers also features Razer's Chroma RGB LED lighting feature, which has 16.8 million customizable colour options.
The tweeters, subwoofer, control pod, and optical + Bluetooth connectivity are exclusive to the Nommo Pro model, which will retail for a not insignificant $499.99 USD.
The Nommo Chroma is a more basic 2.0 speaker system, but it does feature a built-in DAC. This model also features two 3-inch drivers but featuring woven glass instead of kevlar coating. Since it has to make due without the subwoofer, the Nommo Chroma has rear-firing bass ports to add a little extra low-end to the audio. While there is no control pod with this model, the volume knob and bass level adjustment is built right into the stand of the right-hand speaker. The Nommo Chroma features both 3.5mm and USB audio inputs, as well as a 3.5mm headphone jack.
As per its name, this model also features Razer's Chroma RGB LED lighting feature, which has 16.8 million customizable colour options. The Nommo Chroma will retail for $149.99 USD.
Lastly, we have the basic Nommo. This model features the same speakers and design as the Nommo Chroma, but does away with the Chroma RGB LED lighting and the USB connectivity. As a result, it only has 3.5mm input and outputs. On this plus side, this lower-end model retails for a more wallet-friendly $99.99 USD.
The Razer Nommo and Nommo Chroma will be available worldwide in January 2018, while the availability of the Nommo Pro is yet to be determined.
Our full video can be found below as well.
Latest Reviews in CES 2018
January 13, 2018
Cooler Master has unleashed a whole range of new gaming accessories that were all designed entirely by Cooler Master. The M800 Series has arrived!...
January 13, 2018
Cooler Master is attempting to master cooling with a handful of new CPU cooling solutions that feature a heavy emphasis on flashy RGB LED lighting....
January 13, 2018
Phanteks has announced a new Eclipse series case that can handle extra-wide E-ATX motherboards and they have updated their P300 model with some new color options....
