Quantcast
The AMD RX 580 8GB Performance Review
Author: SKYMTL
Date: April 18, 2017
Product Name: RX 580 8GB
Part Number: RX 580 8GB
Share |
There’s no denying in the year since its launch, AMD’s RX 480 and its positioning in the graphics card market has been a hotly debated subject. Some of that is due to the fact that its Polaris architecture effectively remains the only lifeline Radeon fans can cling to in the hopes that something more will eventually be around the corner. However, much of the consternation and hand wringing has been due to that card’s positioning against NVIDIA’s slightly newer GTX 1060. Well today AMD is hoping to put that debate behind us with the RX 580, a spiritual encore presentation to one of their most popular and best-received GPUs of the last few years.
In order to understand the RX 580’s path to inception you have to look back at the somewhat troubled but ultimately successful RX 480. When it was launched, I praised it for focusing on value; it was actually one of the first GPUs to cost less than $300 but provide excellent performance metrics in both 1080P and 1440P scenarios. Unfortunately there were some speed bumps placed along the way since we soon found the reference versions drew excessive power from the PCI-E slot and at least initially, availability was sketchy at best. Things quickly turned around with multiple driver releases and just a few months ago we discovered the RX 480 had become the card to buy, often beating out the GTX 1060 in key gaming benchmarks.
What the RX580 strives to do is further capitalize upon the wave of positive press its now-discontinued sibling received by providing more performance per dollar. To accomplish this AMD us utilizing the same Polaris 10 core we have all come to know and love but through the use of a more mature 14nm FinFET manufacturing process, they have been able to offer substantially increased core frequencies.
There is supposedly also more overclocking headroom for their board partners and end users to tap into. Not only could this positively impact overall value but it could also help AIBs expand their selections of pre-overclocked Polaris-based products.
The RX 580 isn’t the only GPU getting a brand new coat of paint either. Since it is based off of the same yet slightly cut down version of the Polaris 10 core, the RX 470 will be making way for the new RX 570. This review will focus on the RX580 since my RX 570 sample arrived a bit late and with the Easter weekend upon me, there just wasn’t the time to properly execute.
The only other area where the newer Polaris products differentiate themselves from the outgoing cards is within their power consumption algorithms. The older Polaris-based GPUs featured a simple 2-state power system for their memory clocks wherein one was set for idle situations or extremely light workloads whereas the second state was reserved for higher performance situations.
Unfortunately this setup led to the memory entering its high performance mode when two displays were plugged in or when the video decode engine was required for simple online video playback. As a result power consumption in those two scenarios was much higher than it should have otherwise been.
To bypass this issue, AMD has now added a third power state for their onboard memory which sits between the idle and high performance “gears”. The byproduct of this move is lower power needs (and heat production) than before. It should also be noted that reduced single display idle power consumption numbers have been achieved by using that refined 14nm manufacturing process. There’s some hope this will allow standard idle numbers in our tests to register lower as well.
Looking at these numbers should completely eliminate the term “rebrand” from anyone’s mind, even though some will likely be disappointed that we’re still stuck on the original Polaris 10 architecture. Let’s call this a refresh, a refurbishment or a refinement but let’s not come down like a ton of bricks on AMD for sticking with a good thing.
At the top of the current Radeon stack is the RX 580 a card that sticks with the exact same 2304 Stream Processor layout as its predecessor but its Base and Boost frequencies receive a shot of adrenalin. That 1340MHz Boost clock should be easily achievable by the majority of cards since this time around AMD isn’t launching a reference version per se. Rather, board partners will be free to use their own heatsinks so we won’t have to worry about a poor-performing blower style cooler messing with results.
On the memory front all remains the same. Even though there are higher GDDR5 speed bins available these days, AMD has chosen to largely avoid them in an effort to reduce overall board costs. Another thing that should be mentioned is the return of a 4GB card. While the RX 570 will be pulling double duty by competing against the GTX 1060 3GB and GTX 1050Ti, AMD’s intent for the 4GB version this time around is for it to bridge the gap between NVIDIA’s 3GB and 6GB SKUs.
Moving a bit lower in the chart and we come up against two points that will likely prove to be the most controversial. The first of these is power consumption. While there are the minor revisions to Polaris which reduce bottom-end efficiency, there’s no escaping the fact that higher frequencies lead to increased power needs. As a result, the RX 580’s typically board power hovers around the 185W mark while board partners’ versions could top 200W. Given the RX 480’s original 150W rating was hotly debated from day one, this shouldn’t come as any surprise.
Pricing is also something I need to discuss since the RX 480’s $240 MSRP hasn’t budged since its launch. This time around I went to the source –that being board partners- since they’re ultimately the ones who set retail pricing whereas AMD’s numbers are simply a “guidance”.
As it turns out come launch you should be able to find reference spec’d cards for anywhere between $230 and $240USD. Finding those few $ Meanwhile overclocked versions will range from $260 upwards to $280USD. Whether or not there will be many cards available at the $230 mark remains to be seen but I have my fingers crossed.
The RX 570 on the other hand is an interesting little card. Not only does it sport massively increased frequencies over the RX 470 but it also sports a boost to memory frequencies. This should allow AMD’s new $170 GPU to open up a huge lead against the GTX 1050Ti but it also costs about $20 more than the NVIDIA card. Also of note is that the 570 will also be available in 8GB form for about $190.
Moving on to the subject of this review and I have a bit of a yin and yang situation for you. A bit before launch it came to our attention that AMD was seeding cards with their highest speed bin to reviewers. Typically that isn’t a problem since I would also be able to compare it against a typical reference-spec’d card to give a proper idea of what the overall competitive landscape looks like.
That wasn’t meant to be since the only sample I received was a Sapphire RX 580 Nitro+ Limited Edition which will retail for $280USD. Now granted, this card runs at a nominal speed of 1410MHz and has a secondary BIOS which pushes it even further to 1450MHz (for testing I used the default BIOS) but the optics of price become a huge issue. Remember, this is a whole $50 over AMD’s SRP. That may not sound like much but in this segment it is a significant premium.
I reached out to other board partners and in rode XFX at the last minute with their RX 580 GTS XXX Edition a card that has a price of just $240 but boasts close-to-reference speeds (the core is overclocked just 26MHz to 1366MHz) and pricing. With this we can actually get an almost-true apples to apples comparison against a bone stock RX 480 and GTX 1060 Founders Edition. My opinion wouldn’t be clouded by the specter of a $280 price either. For the fun of it I’m also throwing in an EVGA GTX 1060 6GB Superclocked card.
Right now it looks like the RX580 will be an extremely appealing replacement for the RX 480. Not only does it bring more performance to the table but pricing hasn’t increased by any appreciable amount. Meanwhile, NVIDIA doesn’t have anything in their lineup that can effectively compete against this initiative other than their upcoming GTX 1060 6GB 9Gbps edition. So could this finally be a convincing segment win for AMD? Let’s find out.
Latest Reviews in Video Cards
November 15, 2018
The AMD Radeon RX590 is a "new" GPU that's based on old technology. But our performance benchmarks may tell a different story when the RX590 is compared against the RX580 and GTX 1060 6GB....
October 15, 2018
The RTX 2070 launch is upon us and this time we have the $500 ASUS RTX 2070 Turbo and $550 EVGA RTX 2080 XC to check out....
September 18, 2018
The NVIDIA RTX 2080 and RTX 2080 Ti's promise to be two of the fastest graphics cards ever produced. Let's see if our suite of performance benchmarks backs up that claim....
