Quantcast
ECC Memory & AMD's Ryzen - A Deep Dive
Author: MAC
Date: March 30, 2017
Product Name: AMD Ryzen
Part Number: AMD Ryzen
Share |
Turning to Linux
The very latest iteration of the Linux kernel - version 4.10 - fully supports AMD's new Ryzen processors, and arguably the easiest way to take advantage of that kernel is by installing Ubuntu 17.04 (Zesty Zapus). We are also once again fortunate to be using an ASRock X370 Taichi since we were not able to load Ubuntu on a GIGABYTE AX370-Gaming 5.
Since we are interested in determining whether ECC is functional on this new AM4 platform, the next step was to install edac-util, which is an incredibly useful program that reads and reports error detection and correction (EDAC) information. Specifically, this program can tell you if ECC is enabled, and if it is it will report any corrected error (CE) or uncorrected error (UE).
Let's see what we can find:
Success! One memory controller with ECC functionality detected, and no errors to report. We can now confirm that ECC is enabled in Linux.
For more information, we decided to use the dmesg (display message or driver message) command to see what the kernel and/or kernel modules had to say about ECC:
As you can see clear as day: "DRAM ECC enabled". While some of those RAM parameters are obviously not being read correctly, the mention of "x8 syndromes" is another confirmation since syndromes are the eight extra bits that are used for the error detection and correction process.
Just to be thorough, we installed non-ECC memory, ran the same command, and got an ECC disabled message.
We also tried the popular dmidecode utility (sudo dmidecode -t memory), but since it's not EDAC aware it did not detect ECC.
While this all looks incredibly positive, the next step is obviously to determine whether error detection and correction is actually working, and to what extent it is working. Will the operating system detect and log errors? Will the hardware function together to correct single-bit errors and ideally halt the system when there's a two-bit error? That is what we are going to find out next.
Latest Reviews in Processors
November 12, 2018
Intel's i9-9980XE is an expensive flagship processor but it isn't anything new either. This CPU is basically a higher clocked version of the i9-7980XE and Intel may have some challenges maintaining a...
October 18, 2018
With the launch of this 9th generation Core processor family, Intel have finally caught up to AMD in the mainstream processor core war....
August 12, 2018
AMD's second generation Threadripper processor are finally here with the 2950X, a CPU that promises better performance than the 1950X and Intel's 7900X but for less money....
