Feature Testing: Onboard Audio
Since fewer and fewer consumers seem to be buying discrete sound cards, the quality of a motherboard's onboard audio is now more important than ever. As such, we figured that it was worthwhile to take a closer look at the quality of the analog signal coming out of the ASRock X370 Taichi's onboard audio subsystem. As mentioned earlier, this model features the new Realtek ALC1220 codec, a proven Texas Instruments NE5532 op-amp, Nichicon "Fine Gold" audio capacitors, and a PCB-level isolation line that should help protect from electromagnetic interference (EMI).
Since isolated results don't really mean much, but we have also included some numbers from the plethora of motherboards that we have previously reviewed. All of the Z170 models feature onboard audio solutions that are built around the Realtek ALC1150 codec, while the Z270 motherboards all feature the newer Realtek ALC1220 codec. While they may all have similar codecs, there are vastly different hardware implementations that feature different op-amps, headphone amplifiers, filtering capacitors, secondary components and layouts.
We are going to do this using both quantitative and qualitative analysis, since sound quality isn't really something that can be adequately explained with only numbers. To do the quantitative portion, we have turned to RightMark Audio Analyzer (RMAA), which the standard application for this type of testing.
Since all modern motherboards support very high quality 24-bit, 192kHz audio playback we selected that as the sample mode option. Basically, what this test does is pipe the audio signal from the front-channel output to the line-in input via a 3.5mm male to 3.5mm male mini-plug cable, and then RightMark Audio Analyzer (RMAA) does the audio analysis. Obviously we disabled all software enhancements since they interfere with the pure technical performance that we are trying to benchmark.
As you can see, this X370 Taichi model achieved some tremendous results. Its total harmonic distortion (THD) plus noise, intermodulation distortion (IMD) plus noise, and stereo crosstalk numbers are some of the best that we have ever seen on a motherboard. Despite featuring very similar audio implementations, this new AMD model crushes both the ASRock Z270 motherboards.
As we have mentioned in the past, we aren't experts when it comes to sound quality, but at this high level we suspect that just about anyone should be satisfied. We listened to a variety of music and spoken word content using a mix of Grado SR225i and Koss PortaPro headphones, Westone UM1 IEMs, and Logitech Z-5500 5.1 speakers, and the playback was clean and loud. Frankly, we have no criticisms at all.
