Quantcast
Intel Kaby Lake i7-7700K & i5-7600K Review
Author: SKYMTL
Date: January 2, 2017
Product Name: i7-7700K / i5-7600K
Share |
Conclusion; A Refreshing Refresh?
Many of you will likely read through this review and roll your eyes since with Kaby Lake, Intel isn’t breaking their cyclical (and relatively minimal) intergenerational performance improvements. Others may skip this entirely since a lot of the benchmarks have already been leaked and they’ll decide Kaby Lake isn’t for them. If you’ve managed to get this far, you may already know that I think Kaby Lake is actually an excellent refresh of Skylake. It not only adds more performance where it counts but the Z270 platform itself is a very well updated foundation upon which to build a new system.
Honestly, if you looked towards Kaby Lake to provide something different, then you haven’t been paying attention to the fact that Intel is somewhat mired in the 14nm process node and their current architecture simply needs refreshes to keep itself “interesting”. They aren’t facing any overt pressure from AMD for the time being, incremental updates like Kaby Lake are still netting them a 7-12% performance uptick every year and the Core series architecture has stood the test of time. If anything this situation should highlight Intel’s relative strengths instead of giving fodder to their naysayers.
Within this review I tested the new lineup’s two flagship chips; the 7600K and 7700K. There isn’t necessarily a “winner” per se but I feel the lower priced i5-series part provides an awesome bang-for-buck solution. It performed excessively well in gaming due to high base and Turbo frequencies, some basic overclocking saw it hit 5GHz, it is very efficient (a key point for ITX builds) and with a price that’s nearly $100 less than its big brother, some of those much-needed funds could be funneled into a higher end GPU purchase instead. If you absolutely need the multi-tasking goodness granted by an eight thread processor then the i7-7700K would be a great fit unless Broadwell-E and its i7-6900K were factored into the equation.
With that being said it is obvious that Kaby Lake isn’t for everyone. If you are sporting a Haswell or newer system there will be very few –if any- readily apparent performance benefits, especially if you want to play a wait-and-see game with Intel’s Optane. From a percentage basis, overclocking hasn’t changed that much either even though seeing 5GHz out of any processor will cause uplifted eyebrows with even the most jaded power user.
Those who still have an Ivy Bridge or earlier setup should be looking closely at Kaby Lake for a viable upgrade path, if only for the long list of key feature Z270 brings to the table over pre-Z97 chipsets. The processors themselves will naturally outperform Ivy / Sandy Bridge (more on this in an upcoming article) but even the most basic of Z207 boards will run circles around their earlier predecessors. Even pushing aside Optane compatibility, features like USB 3.1, Thunderbolt, M.2 / NVMe implementation, build-in audio support, SSD management algorithms and countless other elements allow these new motherboards to stand head and shoulders above older PCH’s.
Kaby Lake is a step in the right direction for Intel. There’s enough of a performance uplift and motherboard feature set expansion that users of much older systems should look into upgrading. Meanwhile, pricing remains stagnant and there are even a few cost reductions versus Skylake CPUs. I really can’t find anything NOT to like here and I’m sure those praises will be sung all the louder once that i3-7350K drops.
Latest Reviews in Processors
November 12, 2018
Intel's i9-9980XE is an expensive flagship processor but it isn't anything new either. This CPU is basically a higher clocked version of the i9-7980XE and Intel may have some challenges maintaining a...
October 18, 2018
With the launch of this 9th generation Core processor family, Intel have finally caught up to AMD in the mainstream processor core war....
August 12, 2018
AMD's second generation Threadripper processor are finally here with the 2950X, a CPU that promises better performance than the 1950X and Intel's 7900X but for less money....
