Quantcast
TP-Link Archer C3150 802.11AC Router Review
Author: AkG
Date: November 24, 2016
Product Name: Archer C3150
Part Number: Archer C3150
Warranty: 2 Years
Share |
Setup & Installation
The process for setting up the Archer C3150 is extremely straightforward, but as we'll explain in the paragraphs below that is part of the problem. To start the setup process, simply plug the router in and either wirelessly connect to one of the two networks that it will automatically start broadcasting or plug a RJ45 cable into the back. Either way will work, but we recommend the wired option as otherwise you will have to first flip the router over and write down the default password for the 2.4GHz and 5GHz networks.
Once the connection is made, simply type in 192.168.0.1 or tplinkwifi.net into your favorite web browser. There is one caveat with using the latter and not the former, and that is if the WAN port is not connected to the internet it will not work. As such, typing in 192.168.0.1 is the easier option.
At this point things do take a turn for the worse if you're a power user. As expected, once you connect to the router its built-in setup routine will be initiated. This process will literally take seconds to accomplish as it is extremely simplistic and really only covers the absolute basics. To actually setup any of the more advanced features, users will need to either click on the basic or advanced tabs and do things manually. In either case, the Archer will technically be setup and ready for use, but maybe not your exact preferences.
Latest Reviews in Peripherals
January 11, 2018
CORSAIR has just unveiled a whole range of new wireless gaming peripherals for those who prefer a wire-free gaming experience....
December 19, 2016
Is it a router, outer space invader or Cylon Basestar? Linksys' MAX-STREAM EA9500 may look odd but it also happens to be one of the most powerful routers on the market....
November 24, 2016
It may have an understated, boring design but behind the TP-Link Archer C3150's common facade and budget-focused price lies an extremely impressive Wireless AC router. One that deserves your attentio...
