Quantcast
Intel Skylake i5-6500, i5-6400 & i3-6100 Review
Author: SKYMTL
Date: February 21, 2016
Product Name: i5-6500, i5-6400 & i3-6100
Part Number: BX80662I56500 / BX80662I56400 / BX80662I36100
Warranty: 3 Years
Share |
Test Setups & Methodology
For this review, we have prepared a number of different test setups, representing many of the popular platforms at the moment. As much as possible, the test setups feature identical components, memory timings, drivers, etc. Aside from manually selecting memory frequencies and timings, every option in the BIOS was at its default setting.
For all of the benchmarks, appropriate lengths are taken to ensure an equal comparison through methodical setup, installation, and testing. The following outlines our testing methodology:
A) Windows is installed using a full format.
B) Chipset drivers and accessory hardware drivers (audio, network, GPU) are installed.
C)To ensure consistent results, a few tweaks are applied to Windows 8.1 and the NVIDIA control panel:
  • UAC Disabled
  • Indexing Disabled
  • Superfetch Disabled
  • System Protection/Restore Disabled
  • Problem & Error Reporting Disabled
  • Remote Desktop/Assistance - Disabled
  • Windows Security Center Alerts Disabled
  • Windows Defender Disabled
  • Screensaver Disabled
  • Power Plan High Performance
  • V-Sync Off
D) Windows updates are then completed installing all available updates
E) All programs are installed and then updated.
F) Benchmarks are each run three to eight times, and unless otherwise stated, the results are then averaged.
G) All processors had their energy saving options / c-states enabled
Latest Reviews in Processors
August 12, 2018
AMD's second generation Threadripper processor are finally here with the 2950X, a CPU that promises better performance than the 1950X and Intel's 7900X but for less money....
February 11, 2018
AMD's Raven Ridge is finally here but can the Ryzen 5 2400G and Ryzen 3 2200G really deliver in the performance categories where other APU have failed?...
January 7, 2018
At CES 2018, AMD has detailed their strategy for 2018. That includes second generation Ryzen and Threadripper CPUs, new Zen+ architecture and more....
