Quantcast
Radeon Software Crimson; The Review
Author: SKYMTL
Date: November 23, 2015
Share |
Understanding Shader Cache
The Radeon Software Crimson Edition also brings with it something AMD calls Shader Cache which is a novel feature that could help drastically reduce game load time and in-game stuttering.
To understand what Shader Cache does, you first have to understand one of the culprits behind some of the major hiccups in today’s open world games. In order to offer a seamless transition from one zone to another in titles like Dragon Age, Fallout 4, Far Cry 4 and others, a game engine will temporarily store complied shaders within the graphics driver before they are discarded. This is an inherently inefficient system since those same elements will need to be re-complied, re-stored and eventually reloaded whenever that section of the game is visited again.
AMD’s Shader Cache essentially adds another layer to that cyclical compile / load / discard routine by redirecting the compiled shaders to a user’s storage subsystem, be it a hard drive or SSD. This means shaders will be ready to be called upon in their pre-compiled forms within a segmented cache file. As a result, level load times can be drastically reduced in DX10 and DX11 games (no mention was made about DX12 and DX9), especially on systems with slower storage components.
There are many other potential areas that can greatly benefit from Shader Cache. Since pre-complied shaders are stored locally in an area that generally allows for quick access, CPU overhead can be reduced and there may be substantially less in-game stutters as the system doesn’t have to fight to compile / load resources. The potential here is almost limitless, especially when it comes to eliminating those nasty stutters in certain open world games when they try to process shader elements in real-time. You can see what happens in the graph (provided by AMD) above.
Within the new Radeon Software you enable Shader Cache under the Gaming tab or it can be turned on within each game’s individual profile. Its pretty straightforward but there are a few things to remember: in order to actually cache any compiled shaders, at least one run-through of a given level is required so the effects won’t be immediate. In addition, complied shaders will take up a not-so-insignificant amount of your storage capacity (especially if a sub-1TB SSD is being used).
AMD also gives users the option to clear out their Shader Cache file by navigating to AppData\Local\AMD\DXCache. Hopefully at some point in time this function will be integrated directly into the Radeon Software suite.
Latest Reviews in Video Cards
October 15, 2018
The RTX 2070 launch is upon us and this time we have the $500 ASUS RTX 2070 Turbo and $550 EVGA RTX 2080 XC to check out....
September 18, 2018
The NVIDIA RTX 2080 and RTX 2080 Ti's promise to be two of the fastest graphics cards ever produced. Let's see if our suite of performance benchmarks backs up that claim....
August 20, 2018
After more than two years of waiting NVIDIA has finally launched their new GPUs. Based on the Turing architecture the RTX 2080 Ti, 2080 & 2070 look to the past and the future for inspiration....
