Categories
Review Contents:
SilverStone Ensemble EB01 & EB02 Audio System Review
by Robscix     |     June 8, 2008
Electronics Overview
EB02- Amplifier: Tripath TA2021B
This chip amplifier has a very impressive set of specifications and quality amplifiers sporting Tripath amplifier chips are highly sought after. The Tripath TA2021B has a Total Harmonic Distortion (THD) % rating of 0.05% at 13Watts of output power loaded with a 4Ω speaker along with a decent dynamic range of 100db.
These digital switching amplifiers are causing quite the buzz among audio enthusiasts and they are finding their way into many high quality amplifiers. T-Amps have changed the way many audio aficionados view high quality audio and their relatively inexpensive cost coupled excellent specifications and high quality sound have made T-AMP powered units very popular. Tripath powered amplifiers are sometimes referred to as “Class-T” by the DIY audio crowds which is a way of signifying the type of amplifier they are to other audio connoisseurs.
Amplifiers using this “Class-T” technology can usually surpass audio components many times their value and allow many to have quality audio that was previously way out of their price range. These chipsets offer the sound quality of Class AB amplifiers with the high efficiency seen in Class-D amplifiers. With such great efficiency the need for larger passive or active cooling solutions are unnecessary and many audio designers have decided to use inexpensive heatsinks. Note: The heatsink was not removed to prevent damage to the amplifier.
The frequency response of this “Class-T” amplifier is also very impressive as it is extremely linear in nature and would account for much of the T-Amp’s sonic transparency. This Tripath amplifier doesn’t color or alter much of the frequency response in anyway even though there is a roll-off of the bass region starting at about 40hz and the high frequency range but nothing to drastic. After carefully reviewing the components, specifications and auditioning a couple different units based T-Amplifier chipsets, it is easy understand why people are giving them high praise.
TA2021B Specification Sheet
EB01-USB DAC: PCM2702E Digital to Analog Converter
This Digital to Analog Converter (DAC) has been used in many very popular “audiophile” DAC units. It is a Burr-Brown DAC chip which has very low distortion measurements with a THD+N% of 0.002% (typ 16bit), signal to noise ratio of 105dB (typ) and a dynamic range of 100db. This digital to analog converter also has an 8X over sampling filter to further improve the quality of the device. USB functionality is built into the chip itself and the DAC is self powered by the host system’s USB ports. Burr-Brown is known to make high quality DAC chipsets and their high end DAC chips have been used in expensive designs from companies such as Denon and others.
PCM2702E Specification sheet
EB01-USB DAC: OPA340 Opamp
This Opamp is used as a final stage in the EB01 Digital to Analog converter, pulling the signal level up to its final output values. With distortion values of 0.0007% Low noise values and slew rate of 6v/µs this Opamp has found it’s way into many consumer audio designs. This Opamp would be considered generic by the audio crowds and while it will do the job required, there are much better units to use for this position in the circuit. The THD+N vs. Frequency measurement show that this amp has good lower frequency range values but when the frequency approaches higher values the THD+N measurements skew up.
OPA304 Specification sheet
Latest Reviews in Audio
February 15, 2009
The world of high-end headphones isn't as crowded as some might think but when there is a new competitor on the scene, people tend to stand up and take notice. Today we will be looking at the Beats b...
December 24, 2008
Back in November we brought you a sneak peak at the upcoming and highly anticipated ASUS Xonar Essence SXT. Today we expand upon that preview with another look at this card but this time we have driv...
November 12, 2008
ASUS will soon be launching their new Essence STX soundcard which is geared toward headphone and audio enthusiasts in general. We have received an exclusive sneak peak and hands-on session with the c...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/7060-silverstone-ensemble-eb01-eb02-audio-system-review.html
Posted By Date
Silverstone Ensemble EB01 & EB02 Audio System Review - Madshrimps Forum Madness February 10, 2010 07:59 PM
Silverstone EB02 Class-T Audio Amplifier has Tripath TA2021B Chip January 9, 2010 12:37 PM
Asynchronous USB Audio - is it worth it ? November 27, 2009 10:36 PM
Computer to Stereo - Page 4 - AudioKarma.org Home Audio Stereo Discussion Forums November 26, 2009 08:09 PM
Futuremark - News - Newsarticle July 16, 2009 11:04 PM
Blue's News - All the carnage that's fit to post! June 8, 2009 04:11 AM
Silverstone Ensemble EB01 & EB02 Audio System Review May 18, 2009 02:13 AM
Ineressant - Québec Audio & Vidéo (forums de discussion) May 10, 2009 01:28 PM
News des 11. Juli 2008 | 3DCenter.org April 23, 2009 10:38 AM
Noob needs help with DAC... - Head-Fi: Covering Headphones, Earphones and Portable Audio April 23, 2009 07:58 AM
Silverstone Ensemble Audio System - PCSTATS.com April 22, 2009 01:18 PM
Computer to Stereo - Page 3 - AudioKarma.org Home Audio Stereo Discussion Forums April 16, 2009 11:53 PM
Silverstone Ensemble EB01 & EB02 Audio System Review - Madshrimps Forum Madness April 3, 2009 06:16 PM
Silverstone Ensemble EB01 & EB02 Audio System Review April 3, 2009 04:49 PM
Silverstone Ensemble EB01 & EB02 Audio System Review April 3, 2009 02:25 AM
SilverStone Technology Co., Ltd - Designing Inspiration April 2, 2009 09:47 PM
