Categories
Review Contents:
Noctua NH-U12P CPU Cooler Review
by AkG     |     May 26, 2008
Heatsink Construction & Design
(Click on image for a larger view)
On first glance one could easily mistake this cooler for a Coolink Silentator or even Thermalright Ultra 120, and it is only upon close inspection that some of the differences become obvious. The largest and most obvious difference is the fan. Unlike the Thermalright which expects you to supply your own fan (usually either a Scythe F or Noctua NF-P12-1300 has been prefered by reader of our site) the Noctua cooler already comes with one. We will get into more detail about the fan in the next section, but for right now let’s just say there is a huge difference and is like taking twenty dollars off the price of the NH-U12P when comparing it to most other tower style coolers. The same goes for the Silentator, whose fan I was never a big fan of (pardon the pun), and when you compare the SWIF which comes with the Silentator to the Noctua it truly is like night and day.
The second difference is not as glaringly obvious but it is actually the more important of the two. Unlike the NH-U12P which has 4 large heatpipes, the Silentator only has 3. When comparing the Nocuta to the Thermalright things are little more complicated. Both coolers come with four heatpipes (and in the case of the extreme version of the Ultra 120 it has six) yet how they are positioned on the fin array is different; for both companies have taken a slightly different approach to their layout. Noctua has their four heatpipes positioned at about a quarter of the way in from both edges but clustered tightly together into two groups; whereas Thermalright positioned theirs out on the periphery of the fin assembly but spaced them slightly further apart. Neither is right or wrong per say, it just would have been nice to have seen that Noctua positioned their heatpipes in a bit more staggered layout so more air actually hits all four heatpipes, instead of clustering them close together into groups of four. When you get down to it this really isn’t that big a deal because the NF-P12 fan which is included has great static pressure and should be able to effectively cool everything down quite well.
(Click on images for a larger view)
As mentioned, the Noctua NH-U12P is a fairly standard “double 4” heatpipe tower design cooler with a full frame 120mm fan. Some people would call this an 8 heatpipe system but in reality it is really only 4 large “U” shaped heatpipes which start at the top right side of the heatsink, go down through the copper and aluminum base and then terminate at the top left side of the heatsink.
While this cooler is a tower style cooler and yes, this is a rather large example, it is actually shorter and narrower (but deeper) than a Thermalright Ultra 120 (or its extreme brethren the T.R.U.E.). The Ultra 120 is 2.5mm taller (160.5mm vs. 158mm), 6mm wider (132mm vs. 126mm)m yet 7.5mm shallower. All in this makes for a cooler which will fit in cases that an Ultra 120 simply won’t and while it is “only” 2.5mm in the difference this can be the difference between getting a side panel back on or having to get out the pneumatic nibbler to modify said side panel.
Almost as important is the fact the NH-U12P is three quarters of a centimeter deeper than a Ultra 120. While it shouldn’t make any difference compatibility wise, it can make a difference performance wise as each of its fins have much more surface area for air to travel over. Since this combination obviously works for Noctua, who are we to question its quirky measurements (after all its not like any of us fit the Cannon of Human Proportions vis-à-vis Da Vinci’s Vitruvian Man drawings!)
As with many similarly designed coolers, the radiator fins on this cooler are made of aluminum to help radiate heat, yet keep overall weight to a manageable level. The number of fins on the U12P is actually lower than of the previous generation U12F, but it is still has more than enough to provide a huge surface area. The reason Noctua removed some of the fins (the bottom couple to be exact) is to increase the compatibility of this cooler with higher than average motherboard heatsinks. Some of the newer p35, x38 and x48 have huge passive heatsinks which are required to keep the NB/SB and VRMs reasonably cool. I am pleased to report this refit does pay dividends as there was plenty of room between the bottom of the U12P and the copper heatsinks which surrounded it on our Gigabyte P35 DS4 motherboard.
While the fins are tightly packed, Noctua’s engineers have taken a page from other tower heatsinks and have given the fins a textured multi-faceted “face” with an indented center. This approach has been proven to help reduce back pressure allowing the fan to keep the air moving efficiently over the fins. As a side note, Noctua has taken this idea of multi-faceted front and taken it to a whole new level as this cooler has some of the most complex and complete ridges of any cooler we have seen; and in fact makes our highly refined Ultima 90 look crude in comparison. It will be very interesting to see if all this attention to detail pays off in the testing phase!
As you can see, the base is even and free of any major tool marks and has a fairly mirror-like finish (please note the spots on the base were dust and are not scratches) However, just like the Silentator (though not as extreme) there were some minor tool marks which can’t easily be seen but are deep enough to be felt with your fingernail. It is certainly not the best polished base we have seen but it is up there with the best. Overall, the level of quality at this price point was certainly above average.
One thing worth mentioning before we continue is the fact Noctua did not use any sticky protection / warning label on the bottom of the heatsink. Instead they used the alternative method which we like to see; namely they used a hard plastic protective cup which snaps off the bottom when you are ready to install the unit. This is a much better way of doing things as it provides a heck of a lot more protection for the base and you don’t have to spend any time removing crud from the bottom! Noctua may not be the only company doing this but it certainly is appreciated!
Latest Reviews in Air Cooling
November 13, 2008
It seems like lately OCZ has their hands in nearly every facet of the PC hardware market. When they started releasing coolers, many people shook their heads and sai...
October 14, 2008
Thermalright has shown us again and again that they are able to produce some of the best coolers on the market today. Today we will be reviewing a product which exp...
October 6, 2008
Noctua has wowed us again and again with their innovative products in the cooling marketplace. From CPU coolers, to thermal compound, to fans; they seem to have it a...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/6961-noctua-nh-u12p-cpu-cooler-review.html
Posted By Date
Q6600 at 53degrees with Noctua cooler? - Overclockers UK Forums October 24, 2008
I need downgrade advice :( - Page 3 - Overclock.net - Overclocking.net October 13, 2008
Tuesday Shortbread - The Tech Report October 7, 2008
Computer Build Thread - Moe's Stupid Technology Tavern - Penny Arcade Forums October 4, 2008
(new) Computer Build Thread - Moe's Stupid Technology Tavern - Penny Arcade Forums September 26, 2008
Noctua.at - sound-optimised premium components "Designed in Austria"! September 26, 2008
Games On Net • View topic - Overclock Q6600 September 18, 2008
PC-Waves | Noctua NH-U12P Reviews September 12, 2008
GameSpot Forums - PC Hardware Discussion - Overclockers: Post your specs and overclocking results here (OC tutorial inside) September 1, 2008
Internode Games Network :: View topic - Overclock Q6600 August 29, 2008
Quel ventirad pour un phenom 9850? August 10, 2008
GameSpot Forums - PC Hardware Discussion - Overclockers :Post your specs and overclocking results here (OCtutorial inside) July 30, 2008
Tuesday Morning Roundup :: TweakTown July 25, 2008
techPowerUp! :: Review Database July 22, 2008
Noctua NH-U12P (Socket LGA775, AM2 & AM2+) : somuchMORE.biz July 22, 2008
