Included Software pt.2
ASUS CPU-Z is a special edition of CPU-Z especially created to match the aesthetics of ASUS' other software utilities. This edition is found on the included software DVD or the ASUS website, but it is not yet available for download from CPUID.com, though you can download the ROG CPU-Z version.
Turbo LAN is a utility designed to help reduce latency courtesy of cFosSpeed traffic-shapping technology. This utility provides users with a lot of control and monitoring capabilities over every application that is accessing the network. It displays CPU usage, NPU usage, ICMP and UDP average ping, and the network utilization of every system process and program. This tool also allows you give priority to certain applications, and throttle or block others to free network resources for other applications. It is your one-stop tool for monitoring and controlling all network traffic, and it even comes with a little widget for real-time bandwidth information.
ASUS Boot Setting allows users to boot directly into the BIOS without having to repeatedly hit delete during the POST screen. It is a pretty hand tool when you are rebooting as often as overclockers tend to do.
The WebStorage utility is basically the ASUS equivalent of DropBox. It is cloud computing application that gives users web storage and access to data across many devices. All ASUS motherboard owners get a free 5.5GB of storage, you can buy more or be gifted some by ASUS if you referrer your friends. The web interface is pretty standard and utilitarian. Overall, there is not much to complain about, it's a nice freebie if you choose to use it.
ASUS CPU-Z
Click on image to enlarge
Boot Setting
WebStorage
