Quantcast
Corsair Vengeance LPX DDR4-2666 16GB Memory Review
Author: MAC
Date: January 26, 2015
Product Name: Vengeance LPX
Part Number: CMK16GX4M4A2666C15R
Warranty: 3 Years
Share |
Test Setups & Methodology
For this review, we are going to be testing a variety of different frequency and timing configurations while also attempting to keep the CPU and Uncore clocks are identical as possible across all of those configurations, unless otherwise noted. Aside from manually selecting frequencies, timings, and voltages every option in the BIOS was at its default setting.
Intel Core i7 LGA2011-v3 Haswell-E Test Setup
For all of the benchmarks, appropriate lengths are taken to ensure an equal comparison through methodical setup, installation, and testing. The following outlines our testing methodology:
A) Windows is installed using a full format.
B) Chipset drivers and accessory hardware drivers (audio, network, GPU) are installed.
C)To ensure consistent results, a few tweaks are applied to Windows 7 and the NVIDIA control panel:
  • UAC – Disabled
  • Indexing – Disabled
  • Superfetch – Disabled
  • System Protection/Restore – Disabled
  • Problem & Error Reporting – Disabled
  • Remote Desktop/Assistance - Disabled
  • Windows Security Center Alerts – Disabled
  • Windows Defender – Disabled
  • Screensaver – Disabled
  • Power Plan – High Performance
  • V-Sync – Off
D) All available Windows updates are then installed.
E) All programs are installed and then updated, followed by a defragment.
F) Benchmarks are each run three to eight times, and unless otherwise stated, the results are then averaged.
Here is a full list of the applications that we utilized in our benchmarking suite:
  • 3DMark Vantage Professional Edition v1.1.0
  • 3DMark11 Professional Edition v1.0.132.0
  • 3DMark 2013 Professional Edition v1.2.362
  • AIDA64 Extreme Edition v3.00.2536 Beta
  • Cinebench R11.529 64-bit
  • SuperPi Mod v1.9 WP
  • MaxxMEM² - PreView v2.01
  • Sisoft Sandra 2014.SP3 20.28
  • Valve Particle Simulation Benchmark v1.0.0.0
  • wPRIME version v2.10
  • X3: Terran Conflict Demo v1.0
That is about all you need to know methodology wise, so let's get to the good stuff!
Latest Reviews in RAM
March 7, 2016
The Crucial DDR4-2133 32GB memory kit may look unassuming but its combination of huge capacity, good speeds, decent overclocking and a low price make for a perfect combination....
February 25, 2016
DDR4 modules have been pushing the boundaries of speed but with their new Trident Z 3600MHz kit, G.Skill have focused upon delivering extremely low latency as well....
January 12, 2016
The Corsair Vengeance LPX DDR4-4000 is one of the fastest, highest performance memory kits around but with a capacity of just 8GB, will it be enough for today's applications?...
