Crucial DDR4-2133 32GB Memory Kit Review
Author: MAC
Date: January 12, 2015
Product Name: DDR4-2133 32GB Memory Kit
Part Number: CT4K8G4DFD8213
Warranty: Lifetime
Share |
System Benchmarks
In the System and Gaming Benchmarks sections, we reveal the results from a number of benchmarks run with the Core i7-5960X and ASUS X99 Deluxe at default clocks, with the G.Skill memory kit's XMP profile applied, and using own our manual overclocks. This will illustrate how much performance can be achieved at various DDR4 memory speeds and timings. For a thorough comparison of the Core i7-5960X versus a number of different CPUs have a look at our Intel Haswell-E Core i7-5960X Review.
SuperPi Mod v1.9 WP
When running the SuperPI 32MB benchmark, we are calculating Pi to 32 million digits and timing the process. Obviously more CPU power helps in this intense calculation, but the memory sub-system also plays an important role, as does the operating system. We are running one instance of SuperPi Mod v1.9 WP. This is therefore a single-thread workload.
wPRIME 2.10
wPrime is a leading multithreaded benchmark for x86 processors that tests your processor performance by calculating square roots with a recursive call of Newton's method for estimating functions, with f(x)=x2-k, where k is the number we're sqrting, until Sgn(f(x)/f'(x)) does not equal that of the previous iteration, starting with an estimation of k/2. It then uses an iterative calling of the estimation method a set amount of times to increase the accuracy of the results. It then confirms that n(k)2=k to ensure the calculation was correct. It repeats this for all numbers from 1 to the requested maximum. This is a highly multi-threaded workload.
Cinebench R11.5
Cinebench R11.5 64-bit
Test1: CPU Image Render
Comparison: Generated Score
The latest benchmark from MAXON, Cinebench R11.5 makes use of all your system's processing power to render a photorealistic 3D scene using various different algorithms to stress all available processor cores. The test scene contains approximately 2,000 objects containing more than 300,000 total polygons and uses sharp and blurred reflections, area lights and shadows, procedural shaders, antialiasing, and much more. This particular benchmarking can measure systems with up to 64 processor threads. The result is given in points (pts). The higher the number, the faster your processor.
AIDA64 Extreme Edition
AIDA64 uses a suite of benchmarks to determine general performance and has quickly become one of the de facto standards among end users for component comparisons. While it may include a great many tests, we used the AIDA64 Cache & Memory Benchmark in order to tests the raw memory performance, combining copy, read, write and latency tests into one global score. This memory benchmark is a classic way to measure bandwidth of a memory subsystem.
Latest Reviews in RAM
March 7, 2016
The Crucial DDR4-2133 32GB memory kit may look unassuming but its combination of huge capacity, good speeds, decent overclocking and a low price make for a perfect combination....
February 25, 2016
DDR4 modules have been pushing the boundaries of speed but with their new Trident Z 3600MHz kit, G.Skill have focused upon delivering extremely low latency as well....
January 12, 2016
The Corsair Vengeance LPX DDR4-4000 is one of the fastest, highest performance memory kits around but with a capacity of just 8GB, will it be enough for today's applications?...
