Quantcast
Intel Haswell-E i7 5960X Review
Author: SKYMTL
Date: August 23, 2014
Product Name: i7 5960X
Part Number: i7 5960X
Share |
Productivity Benchmarks (pg. 3)
TrueCrypt 7.1
Truecrypt is another freeware gem which allows for on-the-fly disk encryption. More importantly, it fully supports AES-256 encryption methods and multi core processors. For this test, we used the built-in benchmark tool are logged the data throughput for TrueCrypt’s AES-256 encryption method.
x264HD Benchmark
x264 is quickly becoming the new codec of choice for encoding a growing number of H.264/MPEG-4 AVC videos. Think of it as the new Divx of HD and you can understand why we felt it critical to include. Tech Arp's recent development of the x264 HD Benchmark takes a 30 second HD video clip and encodes it into the x264 codec with the intention of little to no quality loss. The test is measured using the average frames per second achieved during encoding, which scales with processor speed and efficiency. The benchmark also allows the use of multi-core processors so it gives a very accurate depiction of what to expect when using encoding application on a typical full length video. We use the second pass of the first test for this benchmark as it fully loads all multi core processors.
Latest Reviews in Processors
November 12, 2018
Intel's i9-9980XE is an expensive flagship processor but it isn't anything new either. This CPU is basically a higher clocked version of the i9-7980XE and Intel may have some challenges maintaining a...
October 18, 2018
With the launch of this 9th generation Core processor family, Intel have finally caught up to AMD in the mainstream processor core war....
August 12, 2018
AMD's second generation Threadripper processor are finally here with the 2950X, a CPU that promises better performance than the 1950X and Intel's 7900X but for less money....
