Included Software
The foremost utility in ASUS' vast software suite is the aptly named Ai Suite III. Whereas ASUS used to have a handful of standalone apps for different functions, many were consolidated under the Ai Suite moniker back in 2011. This system management utility is the hub from which you can monitor system clock speeds, voltages, temperatures, and fan rotation but more importantly it allows users to do both automatic and manual overclocking from within Windows. The utility's third iteration was launched along with the Z87 motherboards, and now it once features a refreshed design and feature set with the launch of the Maximus VII GENE. Let's check it out.
The 5-Way Optimization tab is where you will find the 5-Way Optimization automatic overclocking feature. You will also see very simplified information relating to the other five tabs, such as the Energy Processing Unit (EPU) power saving or performance profiles, Fan Xpert 3 fan speed optimization status, DIGI+ VRM optimization, awesome new Turbo App functionality, and some display-only information regarding TurboV Processing Unit (TPU).
In the top-right corner of the Ai Suite utility is a downwards arrow that activates a dropdown screen when clicked. Here you will be features like Ai Charger+ and USB 3.0 Boost. When enabled, Ai Charger+ allows up to 3X faster charging of devices connected to USB ports, while enabling USB 3.0 implements the UAS Protocol (UASP) USB protocol that greatly enhances speeds while also lowering CPU utilization. The EZ Update tool allows users to update their motherboard's BIOS either directly from the internet or from a downloaded file. Ai Charger+ allows users to supercharge their USB ports, and enable up to 3 times faster charging of mobile devices.
System Information just contains a bunch of basic system information regarding your CPU, motherboard or RAM. You can also find you can find your serial number, BIOS version, etc. BIOS Flashback allows you to copy the content of BIOS1 to BIOS2, as well as force the use of BIOS1 or BIOS2.
At the bottom is a static strip that displays information on CPU and DRAM frequency, real-time voltage and temperatures measurements, as well as CPU and case fans speeds. You can also set safe thresholds for voltages, temperatures and fan speeds as well as setting alerts to warn you of any serious fluctuations. It is essentially a replacement for the Probe II utility.
Clicking on the 5-Way Optimization button reveals the coolest part of the whole Dual Intelligent Processors 5 utility. There is a certain level of fan optimization functionality in this section, but what's really interesting is the automatic overclocking feature. You have the option of 3 different overclocking levels depending on whether you have an unlocked processor or not. We don't want to reveal too much here, so go check out the Overclocking Results section to see how well this auto-overclocking feature worked.
The TPU (TurboV Processing Unit) tab is where you can manually adjust the BCLK frequency or CPU strap (100/125/166/200MHz). You will also be able to change the CPU multiplier, either per core or as a group. There are also an impressive eight adjustable system voltages. You can adjust all these settings on-the-fly without having to reboot the system, except for the CPU strap since it does cause such a dramatic increase in all system frequencies.
In the Graphics Cards section, the Fan Tuning feature will - as you might have guessed - automatically optimize the fan speed of any installed ASUS graphics card(s).
The EPU (Energy Processing Unit) tab is you will be able to fine-tune the various selection of power saving or performance profiles. This is a versatile feature for those who truly care about maximizing energy savings.
The DIGI+ Power Control tab is where you will find the power options for the CPU, System Agent/Memory Controller, and RAM. There are adjustable settings for load-line calibration, current capability, voltage frequency, and phase control. There are different power controls for each memory channel since they are independently powered.
The Fan Xpert 3 tab is, as you might expect, where you can fully manage and optimize your CPU and system fans. While there are now a series of four fan presets (Silent/Standard/Turbo/Full Speed), you can also manually adjust the full fan speed curve to your preferences, or simply use the fully automated Fan Tuning feature.
The Turbo App section allows you set custom system configurations for any applications that you want. For example, if you know that your processor can withstand a higher clock speed in a lightly threaded application, you can see this utility to automatically adjust your system overclock every time you open that app, as well as tweak network priority and audio settings.
Included Software
Ai Suite III
