Included Software
APP Center
The APP Center utility is a new centralized hub for all the in-house utilities that GIGABYTE bundles with their motherboards. It permanently resides in the notification area/icon tray in the right corner of your screen. Not only does it give you one location from which to open or even uninstall all motherboard-related pieces of software, but it also feature a Live Update feature that lets you know if the there's a new version of the software available.
EasyTune
The sleek EasyTune system management utility has been refocused towards its core functions of automatic overclocking and real-time tweaking of system frequencies, timings and voltages. As a result, EasyTune has been stripped of its monitoring and fan control duties, and that functionality has been transferred to the new System Information Viewer tool that can apparently handle these tasks with much lower latency. Having said that, when you launch EasyTune the new Hardware Monitor automatically pops open like a widget on the right side on the screen, and it shows you all the vital system voltages, temperatures, and fan speeds.
As in previous versions, the Smart QuickBoost section is really the most interesting one. First, it contains the Quick Boost feature, which allows automatic overclocking at the touch of a button. Simply pick which one of the three Smart QuickBoost overclock presets that best suits your needs, reboot the system, and voila! Overclock achieved. If you're more interested in seriously reducing power consumption, the Energy Saving preset with underclock the processor to 800Mhz and tweak a bunch of settings to maximize efficiency. Of particular interest to us is the smart Auto Tuning functionality that will automatically overclock your system by going through various tweaking and stability testing phases. As you will see in our Overclocking Results section, we preferred the presets over this supposedly intelligent OC'ing feature. Last but not least is the Advanced sub-menu that allows you to manualky set specific frequency, multiplier, voltage, and memory timing settings.
The Advanced CPU OC section is where you can play around with key CPU clocks, ten important system voltages, and even the operating frequencies of your graphics cards.
The Advanced DDR OC section of the EasyTune app is where you can set the memory multiplier, enable or disable your memory kit's XMP profile, or just tweak a wide range of primary and secondary memory timings. It is basically everything you could want from an on-the-fly system tweaking tool.
The 3D Power utility has the same capabilities as the 3D Power section in the BIOS, and there is a lot of functionality here. Having said that, while PWM frequency, Load-Line Calibration (LLC), and phase control are all things that knowledgeable overclockers might tweak, these are all settings that the overwhelming majority of users will never ever have to use.
In order to make the utility more responsive, all the monitoring and fan control duties were stripped from EasyTune and transferred to a new application, the System Information Viewer. This might seem like a step backwards since usually the aim is to consolidate as many features as possibly into one program, but GIGABYTE claims that by doing this they have managed to greatly reduce the deferred procedure call (DPC) latencies that could interfere with EasyTune's primary functions, i.e. real-time tweaking and overclocking.
The System Information tab is pretty straightforward, it really just shows some very basic information regarding the system clocks and a few details about the system's CPU, memory, and motherboard.
In this new implementation, manual and automatic fan control options have been split into two separate tabs. Smart Fan Auto is where you find four standard fan speed presets, while Smart Fan Advanced is where you will find the auto-calibration feature and where you can manually fix fan speed or have it vary based on temperatures.
The System Alerts tab is where you will find the Hardware Monitor, which display some basic system frequencies, a bunch of system voltages, system temperatures and fan speeds. We would like to see some additional voltage readouts, for the System Agent and Ring Bus for example. System Alerts, is as its name implies, is also where you can set system temperature or fan speed limits, and if those thresholds are crossed you will be alerted.
Included Software
APP Center
EasyTune
