AkG
- Joined
- Oct 24, 2007
- Messages
- 5,270
Hardware Installation
In order to test how different hardware combinations will fit onto this board, we installed a Noctua NH-U12S, a 16GB dual channel kit of G.Skill Trident X memory, and a PNY GTX 780 XLR8 OC video card.
The GTX 780 is a long length, dual slot GPU so it should so provide a good reference for other premium video cards and highlight any spacing issues. The NH-U12 is a moderate sized aftermarket CPU cooler so it should provide a good reference for other coolers so we can see if there any clearance issues around the CPU socket. We installed the memory in the sockets closest to the CPU to ensure clearance with 4 DIMMs.
As expected the Deluxe has a decent amount of room between the memory slots and CPU socket. Because of this there should be no clearance issues with all slots populated with standard height RAM. Of course, very deep CPU cooling solutions will overhang the first and possibly second slots, so proper heatsink selection will still be important.
Also expected users will likely run into clearance issues with any air based CPU cooling solution - even thin profile ones - if they also opt for a memory cooler. This is par for the course for 1150 systems and if your RAM truly needs active cooling we recommend taking the plunge into CPU water cooling to reduce compatibility problems.
On the positive side, our Noctua NH-U12S had no issues physically clearing the MOSFET heatsinks, and we don't foresee any obstacles with even the largest of coolers. However, since these heatsinks do wrap around three sides of the CPU socket, the amount of room between them and a typical heatsink's mounting bracket is limited. So while large air based CPU cooling solutions will technically fit, many will take a contortionist to install all four mounting bolts.
Switching from air to water cooling proved rather uneventful as there is more than enough room between the waterblock and its adjacent components. Once again the gap is rather small and larger water blocks could be a tricky proposition, but installing a typically designed block should prove to be a much easier proposition than installing a tower cooler.
Thanks to the PCI-E slot layout there will be plenty of room between the CPU socket and GPU. By moving the first 16x slot down one space, ASUS has neatly sidestepped any potential problems between the two core components. We honestly wish more companies used an x1 port for the first PCIe slot as it should be the defacto standard.
Overall, the layout and design of the ASUS Z97 Deluxe is well above average and it does allow for a fairly hassle-free installation, though one that is not completely issue free. As long as you are aware of these potential problems and take them into account when making your other hardware component section, you shouldn’t run into any major problems.
