| Sans Digital MOBILESTORE Hard Drive Enclosure Review | ||
| by AkG | May 16, 2008 | ||
| Performance Results Performance TestingRead Bandwidth For this benchmark, HDTach was used. It shows the potential read speed which you are likely to experience with these enclosures. ![]() With read speeds it appears the MobileSTOR抯 burst performance is more or less handicapped by either the motherboard抯 SATA controller or the SIL 5744 controller. Either way it does not really matter as what is really important is the average read speeds. In this area the eSATA connected MobileSTOR simply walks away from the rest of the competition. Even in JBOD performance it is better than the rest. However, as is becoming a reoccurring theme, the USB results are less than one would like to see, they are not abysmal but by the same token you certainly wouldn抰 purchase this unit based of those numbers either. Random Access Time Once again, HDTach was used for this benchmark. This benchmark tests how quickly different areas of the drive抯 memory can be accessed. A low number means that the drive space can be accessed quickly while a high number means that more time is taken trying to access different parts of the drive. ![]() When it comes to random access times the MobileSTOR is very good to good with eSATA but only mediocre to sub optimal over USB. The latencies when using USB are large enough as to be noticeable. It is becoming very obvious the SIL抯 forte is not USB performance; this is OK as its main job is eSATA which performs very well. SIS Sandra This test was run with the removable storage benchmark in Sandra XII Standard. All of the scores are calculated in operations per second and have been averaged out from the scores of 4 test runs. ![]() As we saw with the previous tests, the MobileSTOR is only a mediocre performer when in USB configuration. Oddly enough, only while in RAID 0 is the MobileSTOR a better SiS performer than the single drive Eagle Consus-M. | ||
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/6633-sans-digital-mobilestore-hard-drive-enclosure-review.html | ||||
| Posted By | Date | |||
| May 2008 - Overclockers Australia | November 13, 2008 | |||
| Overclockers Australia - OCAU News | October 28, 2008 | |||
| 每日全球IT测试速递:35款AMD CPU相煎—小熊在线—CPU内存频道 | September 30, 2008 | |||
| Sans Digital MOBILSTORE hard drive enclosure - PCSTATS.com | August 25, 2008 | |||
| Product Reviews | July 17, 2008 | |||
| Home of Sans Digital - Your One-Stop Storage Provider | July 17, 2008 | |||
| Sans Digital MOBILSTORE MS2UTN+B Hard Drive Enclosure Review - DriverHeaven.net | July 17, 2008 | |||
