Quantcast
Plextor M6e 256GB PCIe SSD Review
Author: AkG
Date: May 8, 2014
Product Name: M6e 256GB
Part Number: M6e 256GB
Warranty: 3 Years
Share |
Testing Methodology
Testing a drive is not as simple as putting together a bunch of files, dragging them onto folder on the drive in Windows and using a stopwatch to time how long the transfer takes. Rather, there are factors such as read / write speed and data burst speed to take into account. There is also the SATA controller on your motherboard and how well it works with SSDs & HDDs to think about as well. For best results you really need a dedicated hardware RAID controller w/ dedicated RAM for drives to shine. Unfortunately, most people do not have the time, inclination or monetary funds to do this. For this reason our test-bed will be a more standard motherboard with no mods or high end gear added to it. This is to help replicate what you the end user’s experience will be like.
Even when the hardware issues are taken care of the software itself will have a negative or positive impact on the results. As with the hardware end of things, to obtain the absolute best results you do need to tweak your OS setup; however, just like with the hardware solution most people are not going to do this. For this reason our standard OS setup is used. However, except for the Windows 7 load test times we have done our best to eliminate this issue by having the drive tested as a secondary drive. With the main drive being an Intel DC S3700 800GB Solid State Drive.
For synthetic tests we used a combination of the ATTO Disk Benchmark, HDTach, HD Tune, Crystal Disk Benchmark, IOMeter, AS-SSD, Anvil Storage Utilities and PCMark 7.
For real world benchmarks we timed how long a single 10GB rar file took to copy to and then from the devices. We also used 10gb of small files (from 100kb to 200MB) with a total 12,000 files in 400 subfolders.
For all testing a Asus P8P67 Deluxe motherboard was used, running Windows 7 64bit Ultimate edition. All drives were tested using AHCI mode using Intel RST 10 drivers.
All tests were run 4 times and average results are represented.
In between each test suite runs (with the exception being IOMeter which was done after every run) the drives are cleaned with either HDDerase, SaniErase or OCZ SSDToolbox and then quick formatted to make sure that they were in optimum condition for the next test suite.
Processor: Core i5 2500
Motherboard: Asus P8P67 Deluxe
Memory: 8GB Corsair Vengeance LP “blue”
Graphics card: Asus 5550 passive
Hard Drive: Intel DC S3700 800GB, Intel 910 800GB
Power Supply: XFX 850
SSD FIRMWARE (unless otherwise noted):
OCZ Vertex 2 100GB
: 1.33
Intel 520: 400i
SanDisk Extreme 240GB: R211
Corsair Neutron GTX 240GB: M206
Intel 335 180GB: 335
SanDisk Extreme 2 240GB: R1311
Seagate Pro 600: B660
OCZ Vector 150 240GB: 1.2
Angelbird Adler 640GB: AA3.15
Vertex 460 240GB: 1.0
ADATA SP920 512GB: MU01
Intel 7230 240GB: L2010400
Samsung 840 Pro 256GB:DXM06B0Q
Plextor M6e 256GB: 1.02
Marvell 9183 controller:
Plextor M6e 256GB- custom firmware w/ 21nm Toggle Mode NAND
Samsung MDX controller:
Samsung 840 Pro 256GB - custom firmware w/ 21nm Toggle Mode NAND
SandForce SF1200 controller:
OCZ Vertex 2 - ONFi 2 NAND
SandForce SF2281 controller:
Intel 520 - custom firmware w/ ONFi 2 NAND
LAMD controller:
Corsair Neutron GTX - Toggle Mode NAND
Seagate 600 Pro - custom firmware w/ Toggle Mode NAND
Marvell 9187 controller:
Crucial M500 - Custom firmware w/ 128Gbit ONFi 3 NAND
SanDisk Extreme 2 - Custom firmware w/ 19nm eX2 ABL NAND
Marvell 9189 controller:
ADATA SP920 - Custom firmware w/ 128Gbit ONFi 3 NAND
Barefoot 3 controller:
OCZ Vector 150 (M00) - 19nm Toggle Mode NAND
OCZ Vertex 460 (M10) - 19nm Toggle Mode NAND
Novachips NVS3600A controller:
Angelbird Adler - ONFi 2 NAND
Intel X25 G3 controller:
Intel 730 - custom firmware w/ ONFi 2 NAND
Latest Reviews in Storage
March 6, 2018
The Crucial MX500 follows in the footsteps of some of the best SSDs; the MX300 and MX200. But in a very competitive market, can it even compete these days?...
February 25, 2018
It is the FASTEST SSD we've ever tested, providing unbelievable benchmark performance but the Intel Optane SSD 900P also has some very serious limitations....
January 9, 2018
Toshiba has announced the new RC100 NVMe M.2 SSD Series, which targets value-oriented gamers, DIY system builders, and system integrators....
