Conclusion; Head and Shoulders Above the Rest
Conclusion
These dual GPU reviews typically go the same way for me: I harp on AMD’s solution for being too loud and lacking proper driver support or talk about NVIDIA’s alternative which benefits from a low noise profile and higher performance metrics due to better multi card game profiles. It’s an old story that was getting a bit boring after being repeated from one architectural generation to another. Obviously AMD had enough of hearing the same refrain over and over again since the R9 295X demolishes nearly every preconception I had. It’s that good.
To be completely honest, I had abysmally low expectations for any dual core card derived from AMD’s Hawaii cores. The R9 290X and R9 290 had issues with their extreme TDP values dragging down clock speeds as PowerTune throttled performance in a losing effort to curtail thermals. As evidenced by the HD 7990, cores with rampant temperature output and power consumption don’t make for good bedfellows on a single PCB. While nothing has changed about the Hawaii architecture, AMD’s choice to go with a water cooling setup is an excellent one since the R9 295X2 feels light years more refined than their previous outings.
Let’s take a second to talk about that Asetek-supplied water cooling setup since without it, I doubt AMD would have ever been able to achieve the R9 295X2’s spectacular performance. It uses a single bay 120mm radiator which is compatible with nearly every case on the market and flexible tubing so installation is a breeze. This setup limits the card to an operating temperature of just 65°C while under full load while remaining extremely quiet, effectively eliminating the issues associated with the other cards in the Radeon R9 series.
There just aren’t sufficient words to describe the R9 295X2’s performance. It is obscenely fast and will remain so after hours of gaming since the water loop has thermal overhead to spare. At 2560x1440, the resolution most gamers with disposable income will use, it can’t quite keep up with the GTX 780 Ti SLI but does soundly beat two GTX 780’s. Remember, those solutions are $1400 and $1000 respectively so the R9 295X2’s $1500 asking price doesn’t look like a huge stretch.
Its position against a dual R9 290X setup is a bit less clear since performance was very much similar. However, from a temperature and acoustic perspective, the ball is clearly in the R9 295X2's court.
While the reference R9 290X’s full performance aspects are partially masked by its penchant for throttling (even in Uber mode), AMD’s single to dual GPU scaling is nothing short of spectacular. There were significant performance increases in every game without any of the telltale stuttering that ruined past Crossfire experiences. The frametime results do highlight a few situations where stuttering was apparent but NVIDIA’s dual card solutions suffered the same fate. That points towards game engine problems (no surprise there!) rather than driver or hardware issues.
It goes without saying that Mantle could technically push things even further than what we’ve seen here. However, when playing in ultra high detail environments where the R9 295X2 thrives, Mantle doesn’t make any difference whatsoever when used alongside a fast multi core CPU.
4K and higher resolutions are where the R9 295X2 truly shines. Whereas a single R9 290X couldn’t even finish most of our tests (hence its exclusion from the results), the new Radeon flagship powered through every game without a hiccup. It even managed to completely close the gap with NVIDIA’s GTX 780 Ti SLI, which goes to show that more video memory really comes in handy at 4K.
Throughout the course of reviewing the R9 295X2, I had a constant struggle with how to address its installation foibles. Anyone with an All in One water cooling unit already attached to their CPU may be faced with a dilemma when trying to find a suitable mounting location for another 120mm radiator and its associated tubing. Luckily most modern cases have multiple 120mm locations so that worry is rendered inconsequential.
What really intrigues me about the R9 295X2 is its implications for small form factor mini ITX and micro ATX systems with limited expansion slot options. Its ability to exhaust heat outside the chassis’ confines makes it a perfect companion for space-constrained builds. Alongside a
BitFenix Prodigy and
ASUS’ Maximus VI Impact, this card would provide extreme levels of full-tower sized performance in a system than has a laptop-sized footprint. That’s hard to argue against. Mini ITX is a direction many enthusiasts are now taking in order to save on desk space and the R9 295X2 can add an awesome amount of punch to an SFF build, provided the case is compatible with 12” long GPUs.
It goes without saying that the R9 295X2 is a power hungry goliath but, unlike previous dual GPU generations, AMD has engineered their way around potential roadblocks. While the use of a water cooling loop may be cause for derision among purists, I’d tend to disagree with any dissenting voices. With the acceptance of Corsair’s Hydro series and other AIO units, closed loop liquid cooling setups no longer have a stigma of ridicule attached to them. In this case, water cooling provides excellent temperatures, low acoustics, room for overclocking, awe-inspiring performance, longevity and adaptability into cases that may not react all that well to cards that dump a ton of hot air into their confines. As they say: it just works, and works well.
I’ve prattled on about the R9 295X2’s benefits simply because finding faults with it is next to impossible. Granted, a dual GTX 780 system exhibits better performance per watt and more bang for your buck at 1440P but when moving to 4K, AMD’s latest card begins to pull away. It may not be the best solution for those with dual card capable systems (though two would make for the most powerful gaming rig available) but the R9 295X2 provides a truckload of drool-worthy potential for gamers looking to downsize their system or simply go home with the fastest graphics card around.
