Quantcast
OCZ Vertex 460 240GB SSD Review
Author: AkG
Date: March 10, 2014
Product Name: Vertex 240GB
Part Number: VTX460-25SAT3-240G
Warranty: 3 Years
Share |
Testing Methodology
Testing a drive is not as simple as putting together a bunch of files, dragging them onto folder on the drive in Windows and using a stopwatch to time how long the transfer takes. Rather, there are factors such as read / write speed and data burst speed to take into account. There is also the SATA controller on your motherboard and how well it works with SSDs & HDDs to think about as well. For best results you really need a dedicated hardware RAID controller w/ dedicated RAM for drives to shine. Unfortunately, most people do not have the time, inclination or monetary funds to do this. For this reason our test-bed will be a more standard motherboard with no mods or high end gear added to it. This is to help replicate what you the end user’s experience will be like.
Even when the hardware issues are taken care of the software itself will have a negative or positive impact on the results. As with the hardware end of things, to obtain the absolute best results you do need to tweak your OS setup; however, just like with the hardware solution most people are not going to do this. For this reason our standard OS setup is used. However, except for the Windows 7 load test times we have done our best to eliminate this issue by having the drive tested as a secondary drive. With the main drive being an Intel DC S3700 800GB Solid State Drive.
For synthetic tests we used a combination of the ATTO Disk Benchmark, HDTach, HD Tune, Crystal Disk Benchmark, IOMeter, AS-SSD, Anvil Storage Utilities and PCMark 7.
For real world benchmarks we timed how long a single 10GB rar file took to copy to and then from the devices. We also used 10gb of small files (from 100kb to 200MB) with a total 12,000 files in 400 subfolders.
For all testing a Asus P8P67 Deluxe motherboard was used, running Windows 7 64bit Ultimate edition. All drives were tested using AHCI mode using Intel RST 10 drivers.
All tests were run 4 times and average results are represented.
In between each test suite runs (with the exception being IOMeter which was done after every run) the drives are cleaned with either HDDerase, SaniErase or OCZ SSDToolbox and then quick formatted to make sure that they were in optimum condition for the next test suite.
Please note:
Due to the unique nature of the hybrid setup certain tests results have been omitted as they require an unformatted drive to test or gave erroneous results.
Processor: Core i5 2500
Motherboard: Asus P8P67 Deluxe
Memory: 8GB Corsair Vengeance LP “blue”
Graphics card: Asus 5550 passive
Hard Drive: Intel DC S3700 800GB, OCZ 480GB RevoDrive3 x2
Power Supply: XFX 850
SSD FIRMWARE (unless otherwise noted):
OCZ Vertex 2 100GB
: 1.33
Intel 520: 400i
SanDisk Extreme 240GB: R211
Corsair Neutron GTX 240GB: M206
Intel 335 180GB: 335
Crucial M500: MU02
SanDisk Extreme 2 240GB: R1311
Seagate Pro 600: B660
OCZ Vector 150 240GB: 1.2
Vertex 450 256GB: 2.0
Angelbird Adler 640GB: AA3.15
Vertex 460 240GB: 1.0
SandForce SF1200 Drives:
OCZ Vertex 2 - ONFi 2 NAND
SandForce SF2281 Drives:
Intel 520 - custom firmware w/ ONFi 2 NAND
LAMD:
Corsair Neutron GTX - Toggle Mode NAND
Seagate 600 Pro - custom firmware w/ Toggle Mode NAND
Marvell 'Monet':
Crucial M500 - Custom firmware w/ 128Gbit ONFi 3 NAND
SanDisk Extreme 2 - Custom firmware w/ 19nm eX2 ABL NAND
Barefoot 3 controller:
OCZ Vector 150 (M00) - 19nm Toggle Mode NAND
OCZ Vertex 450 (M10) - 20nm ONFi 2 NAND
OCZ Vertex 460 (M10) - 19nm Toggle Mode NAND
Novachips NVS3600A controller:
Angelbird Adler - ONFi 2 NAND
Latest Reviews in Storage
January 9, 2018
Toshiba has announced the new RC100 NVMe M.2 SSD Series, which targets value-oriented gamers, DIY system builders, and system integrators....
October 15, 2017
Toshiba's OCZ division is back with another affordable mainstream drive, the TR200. But unlike previous launches, the TR200 is going up against some serious competition....
August 29, 2017
After the BX200 took the budget SSD market by storm, the performance expectations for the follow up BX300 are sky high. But can it compete in a cluttered market?...
