CoolIT PURE CPU Cooler Review
by AkG     |     May 5, 2008
Value
The term “Value” is such an amorphous term that it truly has different meanings for different people. For some a CPU cooler is only as good as it overclocking potential, for others it is how quiet it does its job; for others still it’s how effective it is for its cost. We here at HWC try to provide as many answers as possible for the term “Value”. Hopefully by this point in the review people looking at OC potential or loudness levels will have a fairly good idea of what its Value is. For the “best bang for the buck” crowd we have included a chart below showing how much each 1*c less costs when compared to Intel’s FREE stock cooler. No consideration has been made for noise levels, “looks” or any other extraneous factors; this is just raw performance vs. monetary cost. For any cooler which performs worse than the Intel stock cooler a rating of “FAIL” will be given. For any cooler which has a “Value” of more than $10 per 1*C a rating of “FAIL” will be used in the graph but the chart will list its actual “value”.
All prices are based on either their MSRP (if no e-tailer prices were available at review time) or the online price they sold for at the time of their review. IF a CPU cooler does not include a fan the price of a Scythe F has been included ($12).
To make it as easy as possible for you to modify this ratio we have also included the various coolers temperature difference so if you do come across one of them on sale you can easily modify its “Value” rating. We here at HWC are in no way saying this is the definitive answer to “Value”, rather it should be considered another tool to help you make your final decision. After all something is only as “valuable” as what you consider it to be.
E4600 Cooling Value
Please note: This chart has be calculated based upon the differences between Intel stock cooler’s average load at its highest OC on a e4600 @3.2GHz versus various after market coolers average load temperatures (in their stock configuration with MX-2 TIM) also on a e4600 @ 3.2GHz.
If your are looking for a cheap CPU cooling solution, then water cooling is probably not in your near future. At a just a hair over a seven and a quarter dollars the PURE is not a cheap solution. All in one solutions will always be more expensive than semi-finished solutions (where you have to finish the installation and add water yourself) but if your time is valuable to you then maybe, just maybe a plug and play kit is worth the added expense.
Q6600 Cooling Value
Please note: This chart has be calculated based upon the differences between Intel stock cooler’s average load at its highest OC on a Q6600 @3.0GHz versus various after market coolers average load temperatures (in their stock configuration with stock TIM) also on a Q6600 @ 3.0GHz.
Ouch, the PURE just manages to squeak by and not be considered a FAIL. Honestly, the old saying: "you can have cheap, efficient or quiet....pick any two" perfectly sums up the Value of the CoolIT PURE.
Latest Reviews in Cooling
October 12, 2011
September 29, 2011
July 14, 2011
