AMD Radeon R9 290X 4GB Review
Author: SKYMTL
Date: October 23, 2013
Product Name: R9 290X
Share |
Onscreen Frame Times w/FCAT (pg.2)
When capturing output frames in real-time, there are a number of eccentricities which wouldn’t normally be picked up by FRAPS but are nonetheless important to take into account. For example, some graphics solutions can either partially display a frame or drop it altogether. While both situations may sound horrible, these so-called “runts” and dropped frames will be completely invisible to someone sitting in front of a monitor. However, since these are counted by its software as full frames, FRAPS tends to factor them into the equation nonetheless, potentially giving results that don’t reflect what’s actually being displayed.
With certain frame types being non-threatening to the overall gaming experience, we’re presented with a simple question: should the fine-grain details of these invisible runts and dropped frames be displayed outright or should we show a more realistic representation of what you’ll see on the screen? Since Hardware Canucks is striving to evaluate cards based upon and end-user experience rather than from a purely scientific standpoint, we decided on the latter of these two methods. With this in mind, we’ve used the FCAT tools to add the timing of runted to the latency of successive frames. Dropped frames meanwhile are ignored as their value is zero. This provides a more realistic snapshot of visible fluidity.
Latest Reviews in Video Cards
November 1, 2017
Enough of the endless unboxings, rumors and presumptions! The GTX 1070 Ti is finally here and it's performance results are impressive to say the least!...
August 14, 2017
After nearly two years of teases, AMD's Vega 64 and Vega 56 have finally arrived. Can these two graphics cards really compete with NVIDIA's Pascal lineup?...
July 30, 2017
AMD has finally revealed almost everything there is to know about RX Vega including its pricing, performance and specifications. Is it a disappointment or everything we were hoping for?...
