720P Gaming: Deus Ex: HR / Dirt 3 / Skyrim
Processors play a huge roll in gameplay performance since they have to process copious amounts of information for the GPU. In the following tests, we use a simple 720P resolution and the lowest possible detail settings in an effort to remove the graphics processor from the equation and place additional pressure on the CPU. 720P was used since it is a resolution that is extensively used by gamers sporting lower end HDTVs and it doesn’t put as much stress upon the GPU as 1080P.
For every one of the following titles, a simple 1 minute gameplay walkthrough was used and the average frames per second was logged via FRAPS.
RESULTS: At lower resolutions, each processor’s gaming ability is put into stark contrast as the graphics card takes a back seat. Unfortunately the FX-9590 just can't keep up here, which is to be expected.
720P Gaming Benchmarks
