Eldonko
BIOS Rundown p.2
BIOS Rundown
Moving over to the Advanced section, we see there are a number of configuration subscreens for CPU, PCH, SATA, System Agent, USB, Platform Misc., Onboard Devices, APM, and Network Stack.
The CPU Configuration page contains detailed information about the CPU installed as well as settings for hyper-threading and active cores. At the bottom of CPU Configuration, there is a subpage titled CPU Power Management Configuration. Here, Speedstep, Turbo, and C-State settings are found.
The next two subpages are PCH Configuration and SATA Configuration. These pages are fairly straightforward and contain settings for the chipset and SATA drives. However, it is worth mentioning that Intel Rapid Start Technology (RST) and Smart Connect Technology (SCT) can be enabled under the PCH menu. A new feature in the Z87 series BIOS is the ability to rename hard drives under the SATA Configuration page. This is a handy way to keep your drives properly labeled when you have several storage areas and partitions in your system.
The last notable subsection of the Advanced tab is the System Agent Configuration page. It is rather buried in subpages but there is a Graphics Configuration page as well on which settings for the iGPU are found. The iGPU will be disabled by default so to use it iGPU Multi Monitor must be enabled. Under NB PCI-E Configuration, link speeds are selectable, up to Gen 3.
The Monitor section contains the system temperature/power status, and adjustable fan settings with profiles. Fan speeds are customizable based on a number of settings, bringing a whole new level of control with Fan Xpert 2.
The Boot section contains boot priority options and POST options. Here you can also enable Hardware Fast Boot, Boot Logo Display, and DirectKey which will boot the system to BIOS when the DirectKey button is pressed.
Under the Tools menu are three subsections: DRAM SPD Information, EZ Flash 2, and OC Profiles.
DRAM SPD Information shows all installed memory with subsections showing SPD and ASUS OC Profiles allow for saving eight customized OC Profiles suited for different situations. This is a very handy overclocking tool that will save a ton of time. EZ Flash 2 is used for flashing the board’s BIOS from a in a safe and easy manner from a USB stick.
Next we have some brand new UEFI features that ASUS has come up with for the Z87 generation of motherboards. The My Favorites page allows you to add customized BIOS items to a start page and will save navigation time. We set up some of our favorite most-used settings and they worked perfectly.
On the right hand side of each BIOS page are two buttons marked Quick Note and Last Modified. Quick Note allows you to enter notes on settings you have tried instead of using the classic paper and pen method.
The Last Modified feature shows the last saved BIOS settings in case you would like to revert back to a previous setting. An export of these prior settings can also be saved to USB for future use. Similar to Last Modified, when you save the BIOS and exit, a BIOS Settings Change screen pops up to remind you of changes made so you can have one last scan of the changes before exiting the BIOS.
All in all we loved the new BIOS features ASUS included with the Z87 Deluxe and although the board was brand new the BIOS was relatively bug free and easily recoverable when instable settings were used.
BIOS Rundown
