Temperatures & Acoustics / Power Consumption
For all temperature testing, the cards were placed on an open test bench with a single 120mm 1200RPM fan placed ~8” away from the heatsink. The ambient temperature was kept at a constant 22°C (+/- 0.5°C). If the ambient temperatures rose above 23°C at any time throughout the test, all benchmarking was stopped..
For Idle tests, we let the system idle at the Windows 7 desktop for 15 minutes and recorded the peak temperature.
The high end cooling solution installed by AMD onto this card is nothing short of spectacular. It may dump loads of hot air into your case but the three large fans and extensive heatsink keep temperatures well under control.
What you see below are the baseline idle dB(A) results attained for a relatively quiet open-case system (specs are in the Methodology section) sans GPU along with the attained results for each individual card in idle and load scenarios. The meter we use has been calibrated and is placed at seated ear-level exactly 12” away from the GPU’s fan. For the load scenarios, a loop of Unigine Valley is used in order to generate a constant load on the GPU(s) over the course of 15 minutes.
AMD claims the HD 7990 is one of the quietest cards currently available and if fan noise was the only factor in this equation, it would easily outpace competing solutions in this regard.
Unfortunately, coil whine drove our sample’s acoustical profile into annoying levels. In applications where the HD 7990 displayed high framerates it wailed like a banshee and lower performance situations caused it to exhibit an odd “chugging” noise. This proved to be immensely distracting, regardless of how quiet its fans are.
For this test we hooked up our power supply to a UPM power meter that will log the power consumption of the whole system twice every second. In order to stress the GPU as much as possible we used 15 minutes of Unigine Valley running on a loop while letting the card sit at a stable Windows desktop for 15 minutes to determine the peak idle power consumption.
Please note that after extensive testing, we have found that simply plugging in a power meter to a wall outlet or UPS will NOT give you accurate power consumption numbers due to slight changes in the input voltage. Thus we use a Tripp-Lite 1800W line conditioner between the 120V outlet and the power meter.
Shoe-horning two HD 7970 cores onto a single PCB naturally results in some impressively high power consumption numbers. However, due to lower voltages, reduced clock speeds and an efficient cooling system, the HD 7990 requires much less power than a pair of HD 7970 GHz Edition cards. Compared against the GTX 690 however, AMD’s flagship is a porker when under load.
Luckily, it looks like ZeroCore Power is making its presence felt here as the idle power consumption numbers are phenomenal.
Temperature Analysis
Acoustical Testing
System Power Consumption
