Quantcast
Seagate Constellation ES.3 4TB Hard Drive Review
Author: AkG
Date: April 2, 2013
Product Name: Constellation ES.3 4TB
Part Number: ST4000NM0023
Warranty: 5 Years
Share |
ATTO Disk Benchmark
The ATTO disk benchmark tests the drives read and write speeds using gradually larger size files. For these tests, the ATTO program was set to run from its smallest to largest value (.5KB to 8192KB) and the total length was set to 256MB. The test program then spits out an extrapolated performance figure in megabytes per second.
Once again the ES.3 posts some outstanding numbers with excellent single drive performance results and RAID throughput that's just spectacular.
As you can see, once the file size got beyond the 2KB mark the three results single, dual drive and quad drive did start to diverge nicely. Not only does the Constellation prefer to be in RAID configuration, it also scales much more linearly than even a VelociRaptor 1TB drive. The more ES.3 drives which are used the closer the power curves get to being four times better than the single drive results.
Latest Reviews in Storage
January 9, 2018
Toshiba has announced the new RC100 NVMe M.2 SSD Series, which targets value-oriented gamers, DIY system builders, and system integrators....
October 15, 2017
Toshiba's OCZ division is back with another affordable mainstream drive, the TR200. But unlike previous launches, the TR200 is going up against some serious competition....
August 29, 2017
After the BX200 took the budget SSD market by storm, the performance expectations for the follow up BX300 are sky high. But can it compete in a cluttered market?...
