GTX TITAN Under the Microscope GTX TITAN Under the MicroscopeWith its incorporation of high end materials, NVIDIA’s GeForce Titan looks more like the GTX 690 than other members of the GeForce lineup. This shouldn’t be a surprise considering the astronomical $999 price, but the focus here is efficient heat conduction and quiet operation. Plus, it just looks great and only measures 10.5” long, making for an easy fit into nearly any case. Unfortunately, unlike its dual card sibling, the GTX TITAN doesn’t have any of the fancy materials like a silver trivalent chromium finish or injection molded magnesium alloy. Rather, it uses cast aluminum panels which have been bolted together in order to ensure they don’t divert from their laser-like positioning. There’s also a heat resistant polycarbonate window. One of the most important aspects of this design is its ability to exhaust hot air outside of the chassis. This allows the TITAN to become a perfect fit for SFF cases which have limited cooling capabilities and were simply overwhelmed by the GTX 690’s axial heatsink design. The TITAN’s rearmost area is dominated by a secondary heatsink which maximizes the fan’s intake airflow. Power is handled by an 8+6 pin combination, which ensures adequate current while also providing adequate room for overclocking. For those with windowed cases, NVIDIA has provided a glowing GeForce GTX logo that’s been laser cut into the TITAN’s cast aluminum side panel. The backplate doesn’t show any surprises with two DVI connectors as well as full-size DisplayPort and HDMI outputs. Luckily, this allows for triple monitor support without using any adapters, though for 3D Vision Surround you’ll need an expensive active DisplayPort to Dual Link DVI dongle. The TITAN’s primary heatsink is quite extensive and covers the core as well as all front-mounted memory ICs. It uses a closed vapor chamber topped with a dense fin array that is optimized to funnel fresh air quickly and efficiently along with a custom Shin Etsu thermal compound for optimal heat transfer. NVIDIA has also extended the secondary heatsink so it covers nearly all of the VRM components and acts as a PCB stiffener, reducing board flex. With the heatsink removed, the sheer size of the GK110 core becomes evident alongside the 24 GDDR5 ICs (12 on the front and 12 on the PCB’s underside). On reference boards, NVIDIA has installed an advanced 6+2 phase all-digital PWM layout which should provide adequate and stable board current. Finally, the board’s underside reveals a non-standard heatsink bolt pattern which hasn’t been used by any past NVIDIA card. It seems like this PCB layout has been lifted directly from the Tesla version since it features a second 8-pin power connector location which is utilized on some K20x cards. | ||||
