Quantcast
Corsair Hydro H90 & H110 CPU Coolers Review
Author: AkG
Date: March 5, 2013
Product Name: H90 & H110
Part Number: CW-9060014-WW & CW-9060013-WW
Warranty: 5 Years
Share |
A Closer Look at the H90
Unlike most of Corsairís high performance All In Oneís, the H90 comes in a rather low key box which is very similar to the that of the H55. It is packed with information that will help educate first time consumers on exactly what this cooler has to offer.
The H90 resides inside a sturdy cardboard protector with a foam topper layer. This protection scheme is effective at reducing the chances of it being damaged in transit.
The accessories which accompany the H90 are almost identical to the H55 and other Asetek built sealed water cooling devices we have recently looked at. This includes all of the components required for quick and relatively easy mounting on both AMD and Intel motherboards. Like the Corsair H55 and NZXT Kraken series, every one of these components is built to exceedingly high quality standards so longevity shouldnít be a concern.
On a cursory glance the 140mm H90 bears a striking resemblance to the NZXT Kraken X40 which isnít a surprise since both are manufactured by Asetek. Further scrutiny reveals these similarities continue and are more than just Ďskin deepí.
The radiator Ė just like the X40ís - has 13 water channels and uses a moderately low 20s folds per inch. Even the depth of the H90ís radiator - ~27mm Ė is for all intents and purposes the same as NZXTís design. In fact, the only thing which will likely differentiate the two coolers will be the fans.
In comparison to the H80i, H90 should provide better performance since its radiator boasts ~36% more surface area of that of a standard 120mm unit. If Corsair has to play follow the leader with the H90ís radiator, at least they picked a solid design to use.
There are quite a few positive aspects of using the same radiator as NZXT rather than CoolITís standard design since it offers more surface area and slightly less restrictive flow constraints. However, the H90ís standard 3/8Ē tubing just canít compete with the 9/16Ē piping found on some of Corsairís other units. It does however utilize the newer highly malleable rubber type compound material rather than an inflexible FEP design, making for a much easiler installation process.
Even though the tubing and radiator are nearly identical to the NZXT X40ís, Corsair has not simply produced a clone here. In some ways, Corsair would have been much better off doing precisely this as the areas in which they have taken a different approach are not necessarily to the H90ís benefit.
The largest difference between the extremely versatile Kraken X40 and the Corsair H90 is the waterblock itself. Both use the same general internal design but Corsair made the decision exclude Asetekís Ďoptionalí fan controller features. In fact, even though its design is quite elegant, this rather expensive Hydro-series cooler will have to rely upon your motherboardís built in fan controller as it has no abilities of its own.
Corsair states this was done because the Asetek USB controller hardware is incompatible with their Corsair LINK software. However, Asetek does offer a software solution of their own and it would not have been difficult to Ďreskiní it like NZXT did and release it solely for the H90 and H110.
Luckily, the baseís quality and finishing is every bit as good as NZXTís and is everything we have come to expect from Asetek built units.
Since Corsair didnít see the need to include Asetekís optional fan controller they had to make some adjustments to the fan itself in order to ensure optimal airflow for all circumstances. As a result the decision was made to use a low-RPM sleeve bearing unit which may be quiet but is much less capable than the H80iís SP120L, let alone the high performance FX 140LB which accompanies NZXTís Kraken X40. At 1500RPM it can move 94CFM of air while retaining a constant static pressure of 1.64mm which should be adequate for most scenarios but its bearing design may impact longevity.
When taken as a whole the H90ís design is a lot more controversial than the NZXT 40ís, but at least Corsair cannot be accused of simply copying anyone elseís design. The H90 may have a similar hardware foundation but it really has taken a radically different approach to things.
Latest Reviews in Cooling
January 11, 2018
CORSAIR has introduced their most powerful power supply yet and some new additions to their always popular line of Hydro Series liquid CPU coolers....
May 10, 2017
All in one water CPU coolers are everywhere these days but Fractal Design's new Celsius S36 dares to do things differently. At 360mm, it may be long but its price to performance is incredible....
August 11, 2016
Prebuilt AIO or a potentially complicated custom loop? Alphacool believes we shouldn't have to choose and their Eisbaer 240 combines both under one roof and could blaze a new trail....
