Quantcast
EUROCOM Monster Gaming Notebook Review
Author: SKYMTL
Date: February 4, 2013
Product Name: Monster
Part Number: W110ER Monster
Warranty: 1 Year (Upgrades Available)
Share |
Keyboard & Trackpad
Due to such a small chassis footprint Monsterís chiclet-style keyboard hearkens back to the netbook generation, and that's not necessarily a good thing. It is compact and quite restrictive since Eurocom only had a limited amount of space to work with. Unfortunately, this leads to a situation where the key size has been maximized, resulting in very little distance between each of the individual islands. Youíll quickly find yourself making errors and over-reaching for certain keys, particularly when going from a standard keyboard to this one. Using it for extended periods of time gives a sense of claustrophobia and accuracy is next to impossible for anyone with slightly oversized hands.
There are however several redeeming qualities here. The keys exhibit an excellent amount of feedback, keyboard flex is virtually nonexistent no matter how hard this area is pressed and the space barís allotted footprint is quite generous. The inclusion of a non-slip palmrest pays dividends, particularly when gaming or using a word processing application. It keeps your hands firmly placed in a strategic location, regardless of how much sweat is involved. Nonetheless, expect your word per minute rate to be cut in half when using the Monster.
An interesting aspect of this condensed keyboard is the juxtaposition between the items which were sacrificed to optimize space and those which came through unscathed. On one hand, all of the left-hand functions (Tab, Caps Lock and Shift) along with the right justified Enter and Backspace buttons are perfectly sized, making them accessible and easy to find for touch-typists. However, the right Shift button is minuscule and the arrow keys are crammed into an extremely confined space.
From a gaming perspective, the WASD and function buttons are quite small and actually locating them can in a pinch becomes a lesson in frustration. In addition, the lack of backlighting makes it very hard to situate your hands when using the Monster in a dark room.
If youíre a gamer, the trackpad wonít be used all that much while playing and thatís a good thing. Its buttons are a bit hard to press and make a loud "clack" sound when pressed and its finger tracking has a serious case of Tourettes. Everyone needs a bit of resistance on their trackpad to ensure pointer accuracy but the textured, rubberized finish makes this one feel like the onscreen pointer is moving through a vat of molasses.
Double taps are all but ignored unless performed with excess pressure and pinch-to-zoom becomes a hopeless exercise. Then, at other times, it picks up phantom inputs or causes the pointer to jump around like some spasmatic rabbit, regardless of the sensitivity setting.
If we had one recommendation for Eurocom, it would be to ditch the textured finish and use a standard, slightly resistive surface here.
Screen Quality
Eurocomís Monster uses a small 11.6Ē screen which certainly wonít win any awards for color reproduction or contrast but it is still quite acceptable for most uses. Regardless of the professional calibration (a $50 option) we still found certain hues to be under-saturated and blacks lacked richness and depth. This is to be expected from a TN panel but it is still unfortunate since the matte screen on our unit cost an extra $120. At the very least, an IPS panel should be offered as an add-on for true connoisseurs.
On the positive side, this panel is a perfect companion for gaming, exhibiting no apparent ghosting and extremely quick response times. Luckily, the lack of color saturation becomes a secondary concern in these scenarios.
As with all TN panels, this oneís viewing angles are anything but stellar. Any deviation from perpendicular on both the vertical and horizontal axis will lead to washed out colors and drastic reduction in contrast.
The true limiting factors here are size and brightness. The Monster just isnít big enough to house a larger display and its tiny 11.6Ē panel feels horribly constrained, reducing in-game immersion and making us yearn for slightly more real estate. And although reflections are nonexistent with the matte option, the screen lacks sufficient backlight output, resulting in a washed out appearance when used in environments with a lot of ambient light.
Audio Quality
The Monster doesnít incorporate the stand-alone sub-woofer of Alienwareís M14x and some other gaming notebooks but it is still capable of delivering adequate sound reproduction. Its speaker output remains blissfully distortion-free until volume reaches extremely high levels while bass and treble remain tightly under control. At no time did we hear the telltale vibrations that typically cloud most notebook speakers when theyíre pushed above a certain volume.
Under no circumstance the Monsterís down-firing speakers match the sonorous output of its immediate competition but thereís been an effort to optimize certain aspects of the audio experience. The THX Optimizer software allows for some impressive headphone performance and its Surround options do broaden the soundstage. This was also the only notebook Iíve reviewed to date which was able to communicate with my Sony noise canceling earphones without signal distortion.
Latest Reviews in Mobile
May 16, 2017
Budget "gaming" notebooks used to be considered laughable. But now the Acer VX15 and Dell Inspiron 15 7000 Gaming dare you to believe that proper mobile gaming is possible for under $800!...
October 12, 2016
Comparing notebook GPU performance in a true apples to apples situation is challenging but we've done it! In this article we pit the previous flagship GTX 980M against the GTX 1070 notebook edition....
August 15, 2016
The inevitable has finally happened: NVIDIA's Pascal architecture has made its way into gaming notebooks....and it is spectacular. In this review we take a GTX 1070-totting laptop out for a spin....
