Quantcast
NZXT Kraken X40 & X60 CPU Coolers Review
Author: SKYMTL
Date: February 10, 2013
Product Name: Kraken X40 and Kraken X60
Part Number: RL-KRX60-01 & RL-KRX40-01
Warranty: 2 Years
Share |
Closer look at the X60
The X60 is simply a massive 280mm water cooler which uses a radiator that provides a huge amount of surface area but from the tubes on, it uses the same hardware and multi socket mounting system as its smaller X40 sibling. The only difference between X40 and X60 is the inclusion of a second fan and additional mounting hardware to attach four fans.
As with the X40, the X60’s 27mm thick radiator not only has more surface area, but additional water channels which are also longer than any 240mm radiator currently available. For example, a Corsair H100i uses 12 channels which are ~240mm in length while the NZXT Kraken X60 uses 13 water channels which are ~280mm in length. This coupled with the large increase in surface area should translate to best in class cooling abilities.
Unfortunately, the tubing which connects the X60’s impressive radiator to the waterblock is the same which graces the X40. At face value, this wouldn’t be an issue except now its 16” long so crimping becomes an ever-present issue and the pump needs to cope with the increased distance.
To help adequately cool this large radiator NZXT has included two of their new high performance 140mm fans. These ‘liquid state’ (aka Fluid Dynamic) bearing-based FX 140LB fans are the same which are found on the Kraken X40. In other words, they should provide some incredible performance when paired up with such a large radiator.
The water block has also been refined over last Asetek designs and uses 90° connectors to mate the tubing and the water block together, making for an easier installation process. The base comes with pre-applied thermal paste while the quality of the finishing job is well above average.
The only fault that could possiblly be found with the waterblock design is the hardwired cables. While they are indeed sheathed in a tight mesh their length and quantity does make for a rather untidy appearance. In grand total there is a 3pin power connector, SATA power connector cable, a USB internal header connector cable and fan cable with four 4pin fan connector pigtails on it. The lack of an included Molex to SATA adapter is also a touch disappointing since some enthusiasts tend to use every available PSU SATA connector.
Latest Reviews in Cooling
January 11, 2018
CORSAIR has introduced their most powerful power supply yet and some new additions to their always popular line of Hydro Series liquid CPU coolers....
May 10, 2017
All in one water CPU coolers are everywhere these days but Fractal Design's new Celsius S36 dares to do things differently. At 360mm, it may be long but its price to performance is incredible....
August 11, 2016
Prebuilt AIO or a potentially complicated custom loop? Alphacool believes we shouldn't have to choose and their Eisbaer 240 combines both under one roof and could blaze a new trail....
