Quantcast
AMD Vishera FX-6300 & FX-4300 Review
Author: SKYMTL
Date: October 30, 2012
Product Name: FX-6300 & FX-4300
Part Number: FD6300WMHKBOX & FD4300WMHKBOX
Warranty: 3 Years
Share |
System Benchmarks (pg.3)
3DMark06 CPU
While 3DMark06 may be a slightly older synthetic benchmark, its CPU test still allows for multi threaded performance evaluations within a gaming environment. It effectively removes the CPU from the equation, generating a CPU-centric score.
WPrime
wPrime is a leading multithreaded benchmark for x86 processors that tests your processor performance by calculating square roots with a recursive call of Newton's method for estimating functions, with f(x)=x2-k, where k is the number we're sqrting, until Sgn(f(x)/f'(x)) does not equal that of the previous iteration, starting with an estimation of k/2. It then uses an iterative calling of the estimation method a set amount of times to increase the accuracy of the results. It then confirms that n(k)2=k to ensure the calculation was correct. It repeats this for all numbers from 1 to the requested maximum. This is a highly multi-threaded workload. Below are the scores for the 32M and 1024M benchmarks.
RESULTS: Both of these tests show slightly different results. On one hand the 3DMark CPU test shows how the AMD processors can shine in certain situations but the WPrime results tell a different story. While the 6-core FX-6300 can leverage its additional threads to stay ahead of the i3 processors, the FX-4300 gets spanked.
Latest Reviews in Processors
February 11, 2018
AMD's Raven Ridge is finally here but can the Ryzen 5 2400G and Ryzen 3 2200G really deliver in the performance categories where other APU have failed?...
January 7, 2018
At CES 2018, AMD has detailed their strategy for 2018. That includes second generation Ryzen and Threadripper CPUs, new Zen+ architecture and more....
January 7, 2018
