Quantcast
AMD Vishera FX-6300 & FX-4300 Review
Author: SKYMTL
Date: October 30, 2012
Product Name: FX-6300 & FX-4300
Part Number: FD6300WMHKBOX & FD4300WMHKBOX
Warranty: 3 Years
Share |
720P Gaming Benchmarks (pg.2)
Processors play a huge roll in gameplay performance since they have to process copious amounts of information for the GPU. In the following tests, we use a simple 720P resolution and the lowest possible detail settings in an effort to remove the graphics processor from the equation and place additional pressure on the CPU. 720P was used since it is a resolution that is extensively used by gamers sporting lower end HDTVs and it doesn’t put as much stress upon the GPU as 1080P.
For every one of the following titles, a simple 1 minute gameplay walkthrough was used and the average frames per second was logged via FRAPS.
RESULTS: Street Fighter is totally GPU bottlenecked at these lower resolutions, Torchlight seems to be able to take advantage of multiple CPU cores and the result is better performance for the AMD CPUs.
Latest Reviews in Processors
February 11, 2018
AMD's Raven Ridge is finally here but can the Ryzen 5 2400G and Ryzen 3 2200G really deliver in the performance categories where other APU have failed?...
January 7, 2018
At CES 2018, AMD has detailed their strategy for 2018. That includes second generation Ryzen and Threadripper CPUs, new Zen+ architecture and more....
January 7, 2018
