Get Adobe Flash player
AMD Trinity A10-5800K APU Review
Author: SKYMTL
Date: October 9, 2012
Product Name: AMD A10-5800K
Part Number: AD580KWOHJBOX
Warranty: 3 Years
Share |
The Effect of Memory Speeds on IGP Performance
On AMD’s APUs, the integrated graphics processor is linked directly to the system’s memory. Not only does AMD suggest that you have at least 8GB of memory to ensure there’s enough for Windows, applications and GPU use but they also recommends using 1866MHz memory for Trinity. The main reason for this is quite simple: the HD 7000-series cores within this architecture are based off of desktop parts that typically run memory speeds of between 1800MHz and 4000MHz. As such, anything lower than 1800MHz may cause some bottlenecking and lower than expected in-game performance.
In order to put AMD’s claims to the test, we benchmarked a number of applications at 1600MHz, 1866MHz, 2133MHz and a blistering 2400MHz as well. Timings were left at 9-9-9-25 1T and all other methodologies for game testing were left in place.
As we can see, the HD 7660D within the A10 5800K absolutely adores higher memory speeds with significant performance increases being realized across the board. However, framerates start to level out at 2133MHz and bumping speeds up to 2400MHz yields minimal benefits. In our opinion the best route for Trinity users is to buy a good kit of 1866MHz memory and overclock it as needed.
Latest Reviews in Processors
April 29, 2013
The new Heterogeneous Unified Memory Architecture (or hUMA) is part of AMD's HSA feature set and will make its way into the Kaveri APUs.  It is supposed to provide a unified memory address space for b...
March 12, 2013
Considering their architectural differences, AMD's VLIW4-based Richland APUs and the Sea Islands' HD 8000M series may seem like strange bedfellows.  However, AMD has somehow allowed them to work toget...
March 12, 2013
AMD have officially revealed the upcoming Richland APUs, which represent a unique amalgamation of old architecture with new, updated features and additional performance benefits for the mobile market....
