Get Adobe Flash player
OCZ Agility 4 256GB SSD Review
Author: AkG
Date: November 6, 2012
Product Name: Agility 4 256GB
Part Number: AGT4-25SAT3-256G
Warranty: 3 Years
Share |
Read Bandwidth
For this benchmark, HDTach was used. It shows the potential read speed which you are likely to experience with these hard drives. The long test was run to give a slightly more accurate picture. We don’t put much stock in Burst speed readings and thus we no longer included it. The most important number is the Average Speed number. This number will tell you what to expect from a given drive in normal, day to day operations. The higher the average the faster your entire system will seem.
Write Performance
For this benchmark HD Tune Pro was used. To run the write benchmark on a drive, you must first remove all partitions from that drive and then and only then will it allow you to run this test. Unlike some other benchmarking utilities the HD Tune Pro writes across the full area of the drive, thus it easily shows any weakness a drive may have.
While the minimum write performance is a touch lower than we would like to see, both the average sequential read and average sequential write performance are right in line with what we have come to expect from modern drives. In these type of scenarios the choice of NAND has a minimal – at most- impact on overall performance.
Latest Reviews in Storage
May 11, 2013
mSATA SSD drives are all the rage these days and Intel is now jumping head first into the market with their new 525 Series.  In this review, we take a look at the 120GB and 180GB versions, two drives ...
May 2, 2013
Seagate's so-called "hybrid" solutions have been around for a while, successfully combining the capacity of a hard drive with the speed of an SSD.  Their new SSHD series takes this mantra to the next ...
April 16, 2013
Value means a lot in today's SSD market and Kingston's V300 series focuses on exactly that.  With a combination of great performance alongside a highly competitive price and adequate capacity, the V30...
