Get Adobe Flash player
NVIDIA GTX 660 2GB Review
Author: SKYMTL
Date: September 12, 2012
Product Name: GTX 660 2GB
Share |
Under the GTX 660’s Heatsink
Note: we used EVGA’s GTX 660 SC for this section since it uses a reference PCB design. However, the heatsink on the reference card will be different from the one you see below.
Removing the heatsink from this card is extremely easy, which bodes well for anyone installing an aftermarket cooler. Just be aware that there are a few small overhangs that tend to snag the PCB so don’t force anything or you’ll likely crack the plastic casing.
Instead of using a somewhat cheap looking heatsink EVGA’s card uses a large cast aluminum affair that uses a copper contact plate with secondary cooling areas for the VRM modules and GDDR5 memory. This is all tied to a dense fin array that’s directly fed by a copper heatpipe, making it much more substantial than anything we’ve seen from reference GTX 660 Ti and GTX 670 cards. EVGA tells us this is a custom design which is supposed to evenly distribute heat while ensuring all of the components stay at optimal temperature.
The component layout on the GTX 660 is different from previous cards as well since its 4+2 PWM is pushed to the rearmost area of the PCB while the memory modules are loosely spaced around the core’s periphery. Speaking of the GK106 core, at 214mm² it is substantially smaller than the 294mm² of NVIDIA’s GK104 and it does without the large IHS from previous generations.
Latest Reviews in Featured Reviews
September 16, 2012
Corsair's Vengeance 2000 seems to combine everything a gamer could possibly want in a headset:  virtual 7.1 surround sound capabilities, long distance wireless operation and lightweight construction. ...
September 13, 2012
NVIDIA's new GTX 660 is aimed directly at the highly popular $199 to $249 price bracket.  Equipped with a Kepler-based GK106 core, this new card is meant to go head to head against AMD's HD 7870 while...
September 5, 2012
MSI's GTX 670 Power Edition OC has an enviable rap sheet:  it's performance nearly matches a GTX 680, there's a long feature list and the included Twin Frozr IV heatsink is cool and extremely quiet.  ...
