Temperatures & Acoustics / Power Consumption
For all temperature testing, the cards were placed on an open test bench with a single 120mm 1200RPM fan placed ~8” away from the heatsink. The ambient temperature was kept at a constant 22°C (+/- 0.5°C). If the ambient temperatures rose above 23°C at any time throughout the test, all benchmarking was stopped. For this test we use the 3DMark Batch Size test at its highest triangle count with 4xAA and 16xAF enabled and looped it for one hour to determine the peak load temperature as measured by GPU-Z.
For Idle tests, we let the system idle at the Windows 7 desktop for 15 minutes and recorded the peak temperature.
Since most GTX 660 Ti’s will use the same heatsink as the reference GTX 670, EVGA’s expanded version would have given us slightly skewed results in these tests. As such, we installed the reference GTX 670 cooler onto our GTX 660 Ti to ensure our results were in line with those of a standard card. The results are about what we have come to expect from current generation NVIDIA cards: relatively cool with ample room for the increase heat signature that comes with overclocking
What you see below are the baseline idle dB(A) results attained for a relatively quiet open-case system (specs are in the Methodology section) sans GPU along with the attained results for each individual card in idle and load scenarios. The meter we use has been calibrated and is placed at seated ear-level exactly 12” away from the GPU’s fan. For the load scenarios, a loop of Unigine Heave 2.5 is used in order to generate a constant load on the GPU(s) over the course of 20 minutes.
The GTX 660 Ti is one of the quietest reference cards we have tested, even with the lower-quality heatsink installed. This bodes extremely well for any custom cooled products board partners may have waiting in the wings.
For this test we hooked up our power supply to a UPM power meter that will log the power consumption of the whole system twice every second. In order to stress the GPU as much as possible we once again use the Batch Render test in 3DMark06 and let it run for 30 minutes to determine the peak power consumption while letting the card sit at a stable Windows desktop for 30 minutes to determine the peak idle power consumption. We have also included several other tests as well.
Please note that after extensive testing, we have found that simply plugging in a power meter to a wall outlet or UPS will NOT give you accurate power consumption numbers due to slight changes in the input voltage. Thus we use a Tripp-Lite 1800W line conditioner between the 120V outlet and the power meter.
Even though its TDP is listed at 150W, the GTX 660 Ti will typically draw about 134W at default speeds which is only a few watts less than the GTX 670’s 147W. This is understandable as the loss of a single memory controller, some cache and a few ROPs can’t be expected to have all that much impact upon efficiency. With that being said, NVIDIA’s newest card is still quite a bit less power hungry than AMD’s HD 7950 3GB.
Temperature Analysis
Acoustical Testing
System Power Consumption
