ASUS Xonar DX 7.1 PCI-E Sound Card Review
by Robscix     |     April 23, 2008
Electronics Overview
Front channel DAC-CS4398
This Cirrus Logic Digital to Analog Converter (DAC) offers advanced ∆∑ (Delta Sigma) architecture, a 120 dB Dynamic range and -107dB THD+N%. This unit also offer low jitter sensitivity and differential stereo analog outputs. According to the specifications this is a high quality part and a very good choice by the Xonar designers. This unit would usually be seen in high end DVD players and home theatre audio video receivers and ensures the front channel opamp is receiving crisp, clear audio for amplification and signal conditioning to line-level for output to your speakers or receiver unit.
Other Channel DAC CS-4362
This Digital to Analog Converter (DAC) offers 24/192 kHz operation with a dynamic range of 114dB and a THD+N% of -100dB. This DAC system also offers digital interpolation, de-emphasis filtering and volume control with soft ramp of 1db graduations. This is a 6 channel output unit that powers the remaining channels of the Xonar DX card.
While this DAC doesn’t have the specifications of its bigger brother on the front channels, it is still a very reasonable unit to put on an audio device at this price point as it offers great dynamic range and reasonable THD+N numbers.
Recording Channel ADC CS5361
The Analog to Digital Converter (ADC) used on the Xonar DX has a dynamic range of 114dB and a THD+N% of -105dB. This unit will provide quality sound recording capabilities to this card considering the price point. This chip will also convert analog signal inputs from the AUX input, Line input and Microphone inputs. The use of a decent ADC further promotes this card's use in a HTPC role offering clean and clear connections from other audio/video devices such as external CD players and other devices.
Opamps 4580 Series
This opamp seems to be a mainstay in consumer audio design and is now considered a rather generic unit. Believe it or not, this opamp has been seen on audio products from almost every manufacturer as they are rather easy to fit into a design and would be cost effective for mass production. The 4580 series are a cheaper priced unit that will do the job but again, the price point of the card would influence such design decisions.
Opamps 5532 Series
The 5532 is a bi-polar opamp with wide scale usage in consumer level electronics. The specifications on this device are reasonable but again there are better chip amplifiers out there. That being said, this chip has gained extremely wide scale acceptance because of its performance to price ratio since it can give decent performance over similarly priced opamps. The 5532 is considered a “workhorse” a chip that designers fall back on when needing an audio opamp.
PCI-E to PCI Bridge Chip PEX8111
This chip is what gives us one of the best hardware features on the DX: its PCI-E compatibility. Finally we have a card that can use the small PCI-Express X1 connectors. The PEX8111 chipset is a bridging chip that allows designers to connect PCI designed cards and chipsets to the newer PCI Express interface bus.
The bridge chip is acting in a forward bridge capacity on this card since this chip allows the PCI card to connect to a PCI-E connector or in reverse bridging mode allow PCI-E card to connect to a PCI interface.
Latest Reviews in Audio
January 3, 2012
Headsets that claim to be made for the gaming market may be a dime a dozen but finding one that performs well and does so at a reasonable price, isn't all that easy.  Corsair's new analog Vengeance 13...
July 18, 2011
Cooler Master's Storm series of peripherals and cases are marketed towards the gamer market and they're now taking the next logical step with a headset.  The Storm Sirus isn't your typical set of head...
November 29, 2010
ASUS hasn't been in the PC audio market for all that long but in a short amount of time, they have gained the respect of many hard to please audio aficionados.  Their latest creation is the Xense 7.1;...
